Old 2nd September 2009, 06:32 PM   #1
Mark245 is offline Mark245  United States
Default Two Stage Amplifier Question
Hello,
I am building a simple two stage amp that consists of a CE stage followed by a CC state. When the load is sufficiently high i.e. 1k, the output it a clean sine wave. However, for a 10 ohm load or a speaker load of 8 ohms, the output gets clipped off at the bottom. I have attached a schematic and plot of the simulation. The simulation matches what is actually happening on my breadboard testing.
Notice in the simulation plot, the bottom of the sine wave gets clippped for a 10 ohm load. However, at the input to the CC stage, the wave looks clean. So the CC stage is distorting the output. Anyone know why this is happening and any suggestion of how to fix it?
Thanks,
Mark
Old 2nd September 2009, 07:36 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is happening because a common collector stage that is called an emitter follower may be viewed as a diode linearized by feedback. For the upper half-period your transistor delivers current to the load; but for the lower half-period of the sine the resistor in it's emitter delivers the current to the load.
Now, what do you need to change to get higher negative current delivered to the load?
Old 2nd September 2009, 08:18 PM   #3
nigelwright7557's Avatar
The output of your amp is grossly mismatched to the load.
You need to lower the output impedance of the final stage.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 2nd September 2009, 08:21 PM   #4
Wavebourn's Avatar
It is the answer with common words.
I've asked, what needs to be done to get it right?
Old 2nd September 2009, 08:46 PM   #5
Ok so when the current through the 10 ohm resistor into the emitter equals the dc bias current, the transistor cuts off right, thereby clipping the negative half cycle?
Is this why people go with a push-pull output stage instead of the single-ended design?
Old 2nd September 2009, 08:48 PM   #6
You need to put in a transistor to drive the negative half cycle.
You would then need to bias the output stage in class b if your not fussy about the quality or class AB if you want a decent sound.
Look up class ab output style. There are literally hundreds of circuits out there on this forum and elsewhere.
Old 2nd September 2009, 09:33 PM   #7
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Clearly said Anatoliy.
How about this: this output stage (emitter follower) is a class A stage. Therefore, it can only deliver non-clipped signal at 2*quiescent current, which I think is about 3.9V/390ohms *2 is about 20mA into 10 ohms which in turn is about .2V peak-peak. So any signal above that causes clipping because even if the transistor completely closes up, the emitter resistor cannot sink more current.
Solution: increase the standing current by decreasing Re. But watch the heat in that emitter follower!
Or go to a push-pull stage in class AB/B as mentioned. Then you have two transistors that can take turns in sourcing and sinking to arbitrary amounts of current (within reason).
jd
/Another new issue: Linear Audio Volume 3!
Old 2nd September 2009, 10:11 PM   #8
Wavebourn's Avatar
Right Janneman;
It is one half of the answer;
another half is, a standing voltage on emitter must be 2/3 of the B+, instead of a half of it.
Old 3rd September 2009, 01:34 AM   #9
Thanks for all the replies.
Wavebourn, why is it neccessary to have 2/3 of B+ on the emitter? It seems like you could have just whatever as long as you are drawing enough current through the emitter resistor to allow for the full voltage swing. Can you further explain this? Thanks
Mark
Old 3rd September 2009, 04:34 AM   #10
Wavebourn's Avatar
Mark;
what do you mean enough? Do you have an unlimited supply?
Suppose, you still want your amp to be efficient, i.e. to deliver max power on the load per dissipated watt.
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
Amplifier without vas stage bogdan_borko Solid State 27 1st March 2007 01:02 PM
Simple 2 stage PP fet amplifier vuki Solid State 18 6th April 2006 08:39 AM
Can anyone suggest an output stage FET for 2-4 W amplifier? mefistofelez Solid State 0 26th February 2005 05:31 AM
Audio Amplifier Input Stage Randy Knutson Solid State 3 20th June 2004 08:33 PM
Page generated in 0.11057 seconds (80.02% PHP - 19.98% MySQL) with 11 queries
