hi its a citronic ppx 1200.
I have the schematic, there isn't much in it, I set to work blind. symptoms are distortion on one channel, clip light is coming on. I replaced some electrolytic capacitors whilst I was at it, and replaced both clip section transistors, channel is still distorting. Any ideas, differential input differential driver and 5 mosfets output stage I was going to start on the driver stage replacement, any tips if I am in the right place? oh it also has a debalancing 4580? opamp vol controls are alps blues which are known to go duff. what should I replace that with? for '[best' sound, its a very nice sounding mosfet amplifier, with not much wrong and fairly!!! easy access. rather heavy at 30kg tho thanks |
#2 |
Can you get access to an osciliscope because this will save a lot of time and guesswork?
You have a good channel to compare, so you if you can scope the amplifier you could easily track down the faulty area. Without a scope you really are trying to fix the amplifier 'blind'. There is no point in upgrading any components untill you have fixed the fault! |
| Meridian MCD Distorting | doarkface | Digital Source | 0 | 10th February 2009 07:47 PM |
| Distorting Accuphase E-302 | reins | Solid State | 6 | 18th January 2007 07:48 AM |
| Distorting 5687 preamp circuit | dsavitsk | Tubes / Valves | 13 | 14th June 2006 02:31 AM |
| Sub distorting - help please | Simpleton | Subwoofers | 8 | 14th August 2005 06:56 AM |
| Mackie power amp distorting | javey | Solid State | 2 | 20th April 2005 03:45 AM |
| Page generated in 0.05873 seconds (79.10% PHP - 20.90% MySQL) with 10 queries |
