Hi, there,
I have a strange question. Can crimp terminal degrade the sound quality. I build two amplifier prototypes (tha shame design, board, pcb components) for a friend of mine. The first with not good quality signal, power, speaker cables, but with not crimps and the other with ofc (oxygen free) cables everywhere but with crimp terminals everywhere. My friend is very experianced audiphile with very good and sensitive speakers, Generally I trust him. Comparing the two prototypes he insists that the first is far better than the second. So are crimp terminals degrade the sound? Any comment, experiance, knowledge are welcome. I have added crimps for good but I am afraid I have to rework the amp. |
#2 |
I have used similar crimp terminals.
I habitually solder after crimping. Then bend over the cable grip. Is there a way to get the cable grip tangs to pierce the insulation?
regards Andrew T. |
#3 |
Thanks for the reply.
I also soldered the wire and the terminal after crimping but what about the actual male - female contact. This is I am woring (contact capacitance, not perfect contact, ...) I do not know really |
#4 |
Electrons are yellow and more is better!
You should not solder crimped contacts if it got crimped OK. I properly crimped contact forms a airtight joint.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
Which contact you mean, contact between cable and terminal or between male terminal and female terminal. I soldered the first.
Thnx |
#6 |
Peranders,
the crimp lugs are very thin and simply fold over the bared wire. They do not have sufficient stiffness to give a rigid crimped joint and can never give the air tight joint that a proper thick walled tube type crimp terminal would give. They may not be designed for soldering but it sure is easy to do and gives a permanent air tight joint.
regards Andrew T. |
#7 |
Did it Himself
Maybe the issue is the fancy cables, specifically the input screened cable could be causing issues if it's highly inductive or capacitive. Similarly the output cable could be an issue if it's inductance is high. Have you a photo of the wiring layout?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 |
No I am afraid I do not have right now, but anyway rhe input cable is an OCC one wire cable with dielectric.!!!
#9 |
If crimp terminals are new (not oxidated), there are virtually no capacitance and no contact resistance. They have a bad contact only if oxidated, or there is a small or normal oxidation, and only a small current flowing. Avoid using in small signals (amplifier input).
I suspect your friend doesn't like crimp terminal... audiophile guys are strange... Or your amps are not identical... caps and other small things degrade the sounds more then a good terminal. |
#10 | |
ALL the aircraft flying around the world use crimps almost exclusively - more reliable long term than solder. IF it is done correctly! |
| Solder vs crimp? | smithy666 | Equipment & Tools | 57 | 10th January 2010 07:55 PM |
| 3 terminal regulator with 3 terminal shunt reference | BWRX | Power Supplies | 10 | 12th April 2008 03:49 PM |
| Which Paladin die to crimp these ring terminals? | andy_c | Parts | 3 | 27th August 2004 02:14 PM |
| Will an amp significantly alter box volume?? | Grantbo | Subwoofers | 9 | 12th March 2002 11:37 PM |
| Page generated in 0.11318 seconds (80.71% PHP - 19.29% MySQL) with 11 queries |
