Hey,
I have a question about a simple audio amplifier I am building. It consists of a CE stage connected to a CC stage. Very simple. The CE has a .1uF bypass cap from emitter to ground. The problem is that the Vbb bias voltage at the base of the CC stage is .5v lower than I expect(it should be 3 but it is like 2.5v). When I remove the bypass cap on the CE stage, Vbb become the correct 3v value. Any idea why this is happening? I also notice that if I connect a 1uF cap accross the power supply rails, this fixes the problem. Why would this help? Any suggestions appreciated. I can post the schematic if so requested. Thanks, Mark |
#2 |
The circuit seems to be unstable without the power supply bypass cap. You should always use the bypass cap to ensure stability.
#3 |
Your amp is an oscillator!
Removing the CD cap lowers the gain, hence stops oscillating. No reason to be minimalist on supply caps! Stick in a big one! |
| Finding bias point in PP fixed bias | beamnet | Tubes / Valves | 14 | 7th December 2008 01:25 PM |
| It plays! Break in / bias point (SimpleSE) | Zap | Tubelab | 19 | 27th June 2008 07:04 PM |
| High bias point. | jnb | Tubes / Valves | 4 | 7th June 2007 03:39 PM |
| EL84 bias point | Klimon | Tubes / Valves | 2 | 2nd November 2006 07:42 PM |
| The best bias point for KT88 | rossdt | Tubes / Valves | 0 | 27th July 2006 06:24 PM |
| Page generated in 0.06903 seconds (71.64% PHP - 28.36% MySQL) with 10 queries |
