Old 31st August 2009, 09:09 AM   #1
mrfix90 is offline mrfix90  United States
Default DENON AVR-2800 No sound from any channel.
Denon amp that I am trying to repair. It was working fine suddenly it stopped. No more sound. Once in a while comes on , if the receiver is on for sometimes. I am not sure what to change. I guess it is in output stage. Do I have to change the output transistor or it just some kind of relay?
when I turn the receiver on, the power/standby light blinks 7 or 8 times and ralay clicks. But no sound. Please give some input so that I can fix the amp. I am really into it. Any help would be appreciated.
Old 31st August 2009, 01:38 PM   #2
Check for DC on outputs.
One of the channels has DC due to some faulty component.
AV receivers tend to get very hot and some resistors get open-circuit.
Old 2nd September 2009, 05:47 AM   #3
Old 2nd September 2009, 05:49 AM   #4
so problem might be because of resistor? The thing it is just intermittent. Sometimes if I keep it on for a while sound comes back. And than sound becomes scratchy...like skipping cd and than cuts off ..no sound.
Old 2nd September 2009, 08:38 AM   #5
I learned to always check potentially faulty resistors and capacitors...
You may also have problems with any transistor..
Can you measure the voltage at output? Ant DC present?
Try this:
use a 'spare' speaker with a >20 Ohm resistor and a large bipolar capacitor in series. this way any DC will be blocked to the speaker.
If possible, get an cold air spray and put a little of it on each transistor. If there is no difference, spray on resistors starting from output.
Another thing to check: connect a working amplifier to the input of the amp modules of your AVR. If the sound is there and clean, the problem is the module, if not, you can have problems with other part: digital volume control.. maybe not
If you have the service manual, send me a copy and I'll show where to start.
Old 2nd September 2009, 11:17 AM   #6
unclejed613's Avatar
does the display stay lit? if so, have you tried changing surround modes. if you want to bypass the DSP, put it in EXT IN mode and feed signal in through the EXT INPUT jacks on the back. if it works fine that way, you probably have a problem with the DSP board or one of the power supplies feeding it. +/-15V regulators are a common failure item in Denons
DENON AVR-2800 No sound No audio Power on mrfix90 Chip Amps 0 23rd August 2009 08:18 AM
Denon POA-2800 any history? feke67 Solid State 3 14th September 2006 06:33 PM
DENON POA-2800 schematics Sony Solid State 12 11th September 2006 10:49 AM
Denon POA-2800 bekim Solid State 1 25th May 2005 06:53 AM
How to improve a DENON POA-2800? Sony Solid State 4 8th May 2005 11:07 AM
Page generated in 0.08326 seconds (76.67% PHP - 23.33% MySQL) with 10 queries
