One channel perfectly working. Another channel I can hear sound very faint only if I tunr the volume really high. Do I have some kind of bad transistor or bad capacitor?
I am sure the pots are perfect. Please help me if anybody has any idea. |
#2 |
Cracked print somewhere ? might be favourite, or cracked track on a pot.
More info needed. Are all inputs affected ? A quick test is to (very carefully) buzz the inputs to the power amp if you have no test equipment. |
#3 |
#4 |
I have digital multimeter. I tried to buzz but no luck. I can hear very faint sound from one channel if I turn the volume very high. Only problem with one channel.
#5 |
Are you "buzzing" the inputs to the power amp on the PCB itself ?
#6 |
yes buzzed the PCB ..no luck..
#7 |
Does sound like a "fault" as such then on that channel.
Withhout knowing how experienced you are it's difficult to suggest anything. If you have only a multimeter I would compare the DC output voltages of the amp with no signal. Should be zero. And then measure the quiescent current of each channel (volt drop over emmiter resistors) and compare good and bad channels. If that shows nothing then it sounds like an "AC" fault... a cap, broken print etc. |
| Rotel 930ax | josefr | Digital Source | 2 | 31st October 2008 12:44 AM |
| modification cd player Rotel rcd 930ax | hiep | Digital Source | 1 | 10th May 2007 07:18 AM |
| Help - need to repair Rotel RCD 930ax | sanjivs | Digital Source | 0 | 9th February 2004 10:09 AM |
| Page generated in 0.08929 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
