Old 16th August 2009, 10:27 PM   #1
morfic is offline morfic  United States
Default Max "Safe" DC Offset
Tangent suggests 20mV as a safe threshold for DC offset.
Is this an accurate amount, too conservative, too loose?
And are the effects indeed cooked headphones, or does the shift due to the constantly applied voltage "just" bias the headphone?
Thanks,
Daniel
Old 16th August 2009, 11:30 PM   #2
Warp Engineer
On Holiday
AudioFreak's Avatar
It very much depends on the type of driver you are feeding but excessive dc offset will indeed cook a driver if it's severe enough or for long enough.
- Dan
Old 16th August 2009, 11:33 PM   #3
nigelwright7557's Avatar
I really cant see 22mV frying headphones !
A lot depends on what you are driving, speakers can be from 1watt to many hundreds of watts. Poking a few millivolts of DC into a big speaker just wont harm it.
On the other hand a volt of DC offset can dissipate quite a bit of heat in the MOSFET of the rail the DC is offset to.
A classic sign of too big an offset is one transistor of the pair gets hot and the other doesnt.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 16th August 2009, 11:47 PM   #4
I am referring to opamps, not discrete circuits, although in the end i see no difference in the effect on the headphones.
While building my cmoy based on tangent's docs i noticed just how much DC offset a bipolar opamp with large input bias current can create in a circuit not designed for it.
I didn't see the 20mV as a "right above that it'll fry" value
It just made me wonder, in my cmoy i have control over the resistors involved in the amp and i can later just for fun change their values to control the LT1364's high DC offset. But what about the people opamp rolling in amps under the assumption it's all good?
I put the LT1364 in a hybrid amp and while the LME49720 in it shows ,1mV offset, the LT1364 still almost scores 30mV. (It's btw 300mV in my cmoy using the stock resistor values, 100mV with resistor values i happened to have available).
I am impressed how well National controlled the input bias current, since i saw no other (popular) bipolar opamp reach nA range, bipolar opamps seem to be typically more in uA range.
So i was wondering, how much past the 20mV is safe, how much heat is a constant voltage in mV range causing on the driver, or is it all just affecting the dynamic range with the shifted "zero point" (offset + signal reaching the max the headphones could deal with sooner?)
I can't possibly listen to the headphones as loud as they can manage to dish out, so is the DC offset still of concern?
This might actually spill over in my decisions of buying used headphones down the road if damage is indeed a possibility.
Thanks,
Daniel
Old 17th August 2009, 12:04 AM   #5
Geek's Avatar
Opamps?
I have a bunch of generic oldies, TL08x, TL07x and NE553x and all the ones I tested were maybe at largest, 5mV
Maybe I just lucked out?
Cheers!
Old 17th August 2009, 09:27 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
.... times the gain
/Per-Anders (my first name) or P-A as my friends call me
Old 17th August 2009, 10:01 AM   #7
Geek's Avatar
Originally posted by peranders
.... times the gain
Which were all followers... gotcha!
Old 17th August 2009, 11:30 AM   #8
kipman725's Avatar
Send a message via MSN to kipman725
opamps aren't designed for driving headphones directly thats why there are DC offset problems. Looking at the datasheets of most opamps they specify a minimum load of 600Ohm's or greater. Companies make dedicated headphone amplifier chips that are not much more complex to use and will work much better, I don't understand why people don't just use those.
Old 17th August 2009, 03:32 PM   #9
AndrewT is online now AndrewT  Scotland
look at the datasheet for input offset current.
Some opamps have offset current cancellation and these generally don't respond to tweaking of the input pin impedances.
regards Andrew T.
Old 17th August 2009, 11:04 PM   #10
Thanks for all the good info.
I would like to come back to the actual question of what is safe and what really happens to headphones once you go past that though.
thanks,
Daniel
Page generated in 0.20921 seconds (44.46% PHP - 55.54% MySQL) with 9 queries
