Tube Sound ? - meet the Aleph CCS - Page 2 - diyAudio
Old 30th August 2009, 11:41 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Try Zen and another one in a stereo configuration and check if you still have a good stereo image. I mean, use your ears for direct comparison.
Old 31st August 2009, 12:03 AM   #12
Bigun is offline Bigun  Canada
Bigun's Avatar
will do.
Right now I'm listening to TGM1 and TGM2 in stereo. I can tell it's not quite the same as two the same. The bass imaging seems the most affected, the rest of it is pretty good.
Old 31st August 2009, 02:46 AM   #13
ostripper's Avatar
by jerluwoo - The same change in harmonics can be achieved by simply adding a resistor from the output to the "tail" in the ltp of a standard set up using a regular ring of two ccs.
Absolutely , just adding one resistor from my CCS to tail I can double my H2.
By gordy - Ostripper, may I ask which amp provided that clean FFT result? Is it Diy-able or a commercial amp?
Yes you may , That FFT is just the combo of "symasym - the next generation" and "self type 3 EF (hybrid triple)". Even with a TGM type voltage stage the result is sweet.
The switching distortion (H5/7) of the double EF with suckout cap is frequency and load dependent and might negate any H2 "maniplations" .
OS
Old 31st August 2009, 03:17 AM   #14
Bigun's Avatar
Yep, that's what I described and used on my TGM1. But, if you believe simulations, the Aleph modulated CCS is superior in terms of less higher order harmonics.
Old 31st August 2009, 04:02 AM   #15
ostripper's Avatar
That is my point , vanishing H5/7. BUT , if your OP stage is reintroducing it , you are still at ground zero. I am "tinkering" now , to see if the aleph CCS in combo with my new "CCS powered type 3 triple" can come close to eliminating it altogether . just one more device can't hurt.
BTW , on your TGM/aleph , what are your tail currents??
OS
Old 31st August 2009, 11:47 PM   #16
I don't mind the Aleph's gate bootstrap cap, its like a freebie CCS...
But I don't care for the coupling cap. Though Nelson sais his 220uF
is less a problem than non-linear gate capacitance, gate worries me
too...
Anyways, here I direct couple an Aleph through the emitter.
And the split sense resistor, compared to the fixed VBE drop
of one emitter computes all the active current sink magic...
The downside to this, is now your plate is driving the gate of the
mosfet (as if the emitter wasn't there). So you want this gate to
be small and easy to drive. I find a Darlington arrangement drives
friendlier than one huge mosfet.
Old 1st September 2009, 12:42 AM   #17
Above post was intended for your other similarly themed thread.
SET amp using Triode-FET complementary feedback pair ?
I guess I had them both open at once, and got mixed up...
Old 1st September 2009, 01:26 AM   #18
Bigun's Avatar
OS
It would be interesting to combine it with the Triple OS. There's always the danger that my sims are not 'good' in some way I've overlooked so it will be interesting to hear what you discover.
My current thinking now is that the additional benefits of the non-switching CFP output look HUGE so I am only continuing simulations on the combination of TGM-Aleph-(non-switching)CFP.
The tail currents in the sim are running at around 2.7mA, that's means a good solid current down each leg. I haven't looked at the impact of different current levels but the Aleph CCS might not behave so advantageously at low currents.
Kenpeter - thanks for the response, I know it was aimed at my thread on a Hybrid amp in the tubes forum but I think this is the right thread to talk about the Aleph CCS - the other thread is really to focus on a Tube-MOSFET CFP hybrid and the Aleph CCS is simply a carry-over from my use of the Zen amp as a starting point. I fear I have too much going on !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
sweet sound aleph-3 or Aleph-x? space2000 Pass Labs 6 28th June 2008 05:36 AM
The Central Sound DIY Audio Meet TerryO Everything Else 71 9th September 2007 07:52 PM
P-audio 15 coax - how do they sound? - do they meet spec? freddi Multi-Way 2 18th January 2007 04:58 AM
the sound of DIY aleph X elviukai Pass Labs 9 5th May 2006 06:17 PM
Balanced MM phono stage : When Aleph Ono and Xbosoz meet... CheffDeGaar Pass Labs 39 18th August 2005 12:42 PM
Copyright 1999-2017 diyAudio
