diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Replacement for LM318H Op AMP in BGW AMP 750 A/B (http://www.diyaudio.com/forums/solid-state/150257-replacement-lm318h-op-amp-bgw-amp-750-b.html)
qsa 29th August 2009 02:35 PM
Hello is there replacement for LM318H possibile ?
Want improve sound in mid and high
How about LME49710 or NE 5534 as replacement
I think amplifier can better sounding with new op amp LME49710
jackinnj 29th August 2009 04:13 PM
LME49710HA about $8.30 from DK
jcx 29th August 2009 05:39 PM
the circuit makes a difference - the 318 was sometimes used with a discrete fet input bypassing its inupt diff pair- not many pin compatiable drop-ins for that cirucit
anatech 29th August 2009 11:41 PM
Keep the LM318. It's the best op amp for that circuit. There are other things you should be paying attention to, like the DC offset adjustment. Output transistor matching, in fact, try some of the newer outputs.
In feed forward, the LM318 is capable of slewing at 70 V/uS. That's faster than what you are looking at as replacements.
-Chris
Lenin21 30th May 2012 11:33 AM
LM318 - Good, but not the best...
Use one of Linear technology's higher spec versions of the LM318/LM118 - the LT318A/LT118A.
A drop-in replacement, lower noise, better PSRR.
djk 1st June 2012 01:40 PM
Fix the coupling caps in the BGW first, the opamp is trivial by comparison.
carlmart 2nd June 2012 06:44 PM
Originally Posted by djk (http://www.diyaudio.com/forums/showthread.php?p=3044728#post3044728)
I couldn't agree more with this statement.
Improving C1 (10uF electrolytic) and C3 (50uF electrolytic) quality might improve things a lot more than swapping the 318.
Copyright 1999-2017 diyAudio
