Old 28th August 2009, 09:58 PM   #1
Question Internal guitar preamp and impedence transformer
Essentially I want a circuit that can transform my passive pickups to actives. I have searched around on google a bit, and found one circuit that uses a single FET. It looks good, but I want to know what other folks have tried. I am trying to get extremely high gain output, for playing metal, etc. Essentially what I want is something like the EMG afterburner, but I want to be able to customize it and of course have the fun of building it myself.
Any ideas? Has anyone done something similar?
Old 28th August 2009, 11:40 PM   #2
nigelwright7557's Avatar
Do you want an external box or something to fit inside your guitar ?
I use a Zoom 707 effects pedal for my sounds.
It was about £150 but worth every penny for the massive amount of different sounds it can create.
If you just want valve type overdrive metal sound then a soft limiter is a good circuit. Or just buy in one of the many valve type distortion boxes.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 29th August 2009, 08:23 PM   #3
I want something that converts my passive pickups to actives. Thus, it should fit neatly inside my guitar. I am looking for the preamp schematic that EMG uses, but something similar would be great.
Thanks!
Old 31st August 2009, 09:49 AM   #4
Elvee is online now Elvee  Belgium
Have a look at this discussion:
Discrete guitar preamp
Old 31st August 2009, 12:15 PM   #5
gagnou is online now gagnou  Greece
gagnou's Avatar
You can also check this: http://www.angelfire.com/az3/dimitri/images/ea0594.pdf by Dimitri Danyuk
Old 31st August 2009, 03:16 PM   #6
Steve Eddy's Avatar
EMG active pickups preamp circiut schematic.
se
Old 31st August 2009, 11:42 PM   #7
Thank you all! Extremely helpful.
I am going to attempt to build this:
http://music-electronics-forum.com/t9095/
and wire it up to my EMG HZ (passive) to attempt to get the EMG 81 sound. I realize that the EMG 81s are wound with thicker wire and less turns, so they get lower noise, but I am going to see what happens. Perhaps a boss ns2 will cut down the noise.
I might also attempt to build this:
And I will read through this thread and pull any useful info out:
I will report back on my progress.
Cheers!
Variable Impedence Mic Preamp philipbarrett Tubes / Valves 1 23rd October 2005 04:36 PM
Guitar pickup internal preamp AudioWizard Solid State 4 17th February 2005 04:56 PM
What Internal Volume for a guitar cab? Mind Riot Multi-Way 4 24th February 2004 09:55 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09602 seconds (75.83% PHP - 24.17% MySQL) with 10 queries
