Old 31st January 2012, 08:08 AM   #21
tiefbassuebertr's Avatar
Originally Posted by fjc View Post
Test on sonic difference,
Anyway, I made listening test on ADA4627 Brz and 4637 Arz.
Sonically they are not much difference. Check the spec, 4627 has a 18 V/us slew rate, normally this should be enough for an audio purpose OP. 4637 has much faster slew of 100s. My feeling is the resolution of 4637 is slightly better,but the major difference is the sense of the instrument locations. It is more alive and sharper image for 4637. In other words, 4627 is more flat. I vote for the 4637, even it is a cheaper A version used.
These differences correspond to those, which I have in mind from the 80s - by a listening test between Raytheon's OP27 and OP37 in the TO outline - go to
OP-37* datasheet and application note, data sheet, circuit, pdf, cross reference, pinout | Datasheet Archive
and
OP-27 OP-27 Noise Operational Amplifier Very noise Spec | Datasheet Archive
for download the associated datasheet.
BTW I am still looking for the internal schematic of ADA4627/4637.
Burr Brown OP-AMP? joetama Solid State 4 21st May 2008 11:53 PM
Burr Brown Opamps coming this week OPA627/637 LongJohnny Vendor's Bazaar 46 4th May 2008 12:54 PM
Burr Brown DIR 1703 snoopyma Digital Source 2 19th April 2007 03:04 PM
Burr Brown Pcm 65 dac rickpt Digital Source 1 12th June 2006 05:33 PM
Page generated in 0.06121 seconds (65.55% PHP - 34.45% MySQL) with 10 queries
