In my amp there is a NJM4580 from JRC, one half being used as DC servo and the other as an input buffer for the amp. It is dead because of its zener supplynow being a short to the positive rail.
I cannot source any NJM4580. Is there a suitable replacement which can do both functions equally well? NE5532 (which I have plenty) maybe? Regards |
#2 |
If you really want NJM4558 then go to the scrapyard and pick up any ghettoblaster or cheap stereo.
Or You could just use your NE5532 and then you will experience much better sound quality. But change the similar one in the other channel.
STOP - Hammertime! |
#3 |
you can use a wide range of dual op amps
I would try the follow: OP-275 (Analog Devices), OPA-2132, OPA2604 and NE5532 (last three from TI) please go also to http://www.diyaudio.com/forums/showt...?postid=448316 Datasheet NJM4580: http://akizukidenshi.com/download/NJM4580.pdf Datasheet OP-275: http://www.analog.com/static/importe...eets/OP275.pdf |
| NJM4580 to OPA2228, which one exactly? | minnie | Parts | 2 | 8th November 2008 12:14 AM |
| JRC NJM4580 (or Behringer UB802) as headphone amp ? | percy | Headphone Systems | 7 | 24th February 2006 05:39 AM |
| where can I get a SSOP8 NJM4580 ? | ashok | Parts | 5 | 22nd February 2006 10:38 AM |
| How to upgrade CDP head phone amp (NJM4580) | DIAR | Chip Amps | 7 | 30th July 2004 01:23 AM |
| NJM4580 SIP op amp... where to buy in USA? | Stephen D | Solid State | 2 | 6th April 2004 07:37 AM |
| Page generated in 0.07980 seconds (68.40% PHP - 31.60% MySQL) with 10 queries |
