#21 | |
so, i see all the issues over models
did anyone BUILD it yet and poke on it? what happened? mlloyd1 Quote:
#22 | |
Attached a picture about what I mean. When I have time next weekend I will do some Spicy simulations. Although the Hitachi fet models I have are not that accurate. Cheers |
#23 |
How to create this graphic plots ?
Could you send me the complete spice circuit and plot command ? |
#24 | |
the green line showing the ideal characteristic of subtracting the perfect transfers from each other cannot be achieved in ClassAB. The subtraction problem is particularly accute over the middle portion where the line develops a wobble. It was this wobble that D.Self majored on in his papers and books on the the "blameless" and subsequent amps.
regards Andrew T. |
#25 |
You've just got to love well menaing replies to miraculously resurrected threads.
Do wizards use spell checkers? |
#26 |
Hi all,
yes I have tried Mosfet drivers with Bipolar outs in CFB coubling and it worked quite well, but I did not ultimately like the sound of it... Also You still need to employ Emitter resistors with the bipolars in order to prevent thermal runaway and current hugging between devices, so maybe there's not that much won here... Cheers |
| LME49810, LME49830 or LM4702? BiPolar or Mosfet output? | sendler | Chip Amps | 27 | 6th March 2009 02:42 AM |
| bipolar full vs semi complimentary output stage | wleediy | Solid State | 0 | 17th June 2007 02:35 PM |
| Bipolar output stage prefers capacitive or inductive load? | Paul W | Solid State | 14 | 7th October 2006 02:44 PM |
| Comparison between Bipolar transistors and MOSFET as output devices | raveenvijendren | Solid State | 4 | 17th November 2005 04:28 PM |
| Mosfet drive in Vas stage and use Bipolar output | YUTK | Solid State | 0 | 26th May 2005 05:50 AM |
| Page generated in 0.08935 seconds (75.41% PHP - 24.59% MySQL) with 11 queries |
