transformer ratings... pls help - Page 4 - diyAudio
Old 18th May 2003, 01:08 AM   #31
keep working and if any question just ask........
Old 23rd July 2010, 10:57 AM   #32
AJT is offline AJT  Philippines
AJT's Avatar
time to give this thread a second life....
most likely, the transformer primary had fewer turns than what was required, magnetizing current was probably high....
add to that a high primary voltage and you get a heated transformer.....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 23rd July 2010, 11:42 AM   #33
Yes a mains transformer designed for 115/230Vac 60Hz will perform adequately. But has it been designed for universal use?
Will it work within specification if the supply voltage is 120/240Vac?
Will it .... is 127/254Vac (max tolerance of most mains)?
Will it work with 50Hz rather than 60Hz?
Will it still be within specification?
To be classed as a universal transformer it must remain in specification with 127/254Vac 50Hz as the worst case supply voltage.
I would expect it to be labeled:
110/120 or 220/240 Vac 50/60Hz
And for the manufacturer to publish the specification details that apply.
regards Andrew T.
Sent from my desktop computer using a keyboard
ratings of output transformer??? cbutterworth Tubes / Valves 6 24th January 2008 04:16 PM
Little help understanding Transformer ratings randy5235 Power Supplies 12 11th December 2006 07:43 PM
PSU Transformer ratings? wildswan Power Supplies 6 11th May 2006 08:54 AM
Transformer ratings??? AR1 Power Supplies 2 2nd May 2005 08:02 PM
Torroidal Transformer ratings kestrel200 Chip Amps 2 8th May 2004 05:59 PM
Copyright 1999-2017 diyAudio
