Old 25th August 2009, 06:41 AM   #11
tubee is offline tubee  Netherlands
tubee's Avatar
Yes because of the fin on collector i discovered the wrong placement of my replacement transistors: 2SA1011/2SC2344
Thanks all for reply. I will revive a 7ties Sony amp in a short momentand hope my work is done tidy.
Daisy Bell
Old 25th August 2009, 06:55 AM   #12
Banned
tubee,
what output devices are used in that amp?
Old 25th August 2009, 07:51 AM   #13
tubee's Avatar
Sony Vfets 2SJ18/2SK60 cascaded with transistors. Replaced the bipolar transistors with D44H8/D45H8, so it should drive an 4 ohm load. It is the TA-N7B amp.
Daisy Bell
Old 25th August 2009, 07:59 AM   #14
tiefbassuebertr's Avatar
Originally Posted by tubee View Post
I am searching for the pin order of these transistors. Searched some while on www no result.
Anyone?
SONY 2SA835 can replace through Motorola MPS-U60
SONY 2SC1663 can replace through Motorola MPS-U10
pinout and outline is the same by all types - go to
http://pdf1.alldatasheet.com/datashe...A/MPS-U10.html
http://pdf1.alldatasheet.com/datashe...A/MPS-U60.html
This information I read in the same order by follow comparsion table books in German Language
1) ECA "tvt transistoren2 '79/80
2) JAEGER ELEKTRONIK Vergleichstabelle 2001
Old 25th August 2009, 08:42 AM   #15
Banned
tubee,
Nice devices in a nice configuration. Are you sure that all of them are defective?
Anyway, it`s going to be a degrade not an upgrade.
Old 25th August 2009, 09:04 AM   #16
tubee's Avatar
I am busy with this beast for a year now. 1 fet was burned and 2 drivertransistors and 1 cascaded transistor.
I replaced the cascade transistors to heavier ones, they are the cause of Vfet failure, and want to prevent expensive obsolete Vfet frying again.
All caps are replaced except the big Lytics, all fusible resistors and some diodes/zeners.
So if someone has (a supplier for) Nippon Chemicon 27000uF/80V lytics.
Daisy Bell
Old 25th August 2009, 10:11 AM   #17
Banned
Suggestion #1
Old 25th August 2009, 04:30 PM   #18
tubee's Avatar
I rather like to keep the Vfets.
Daisy Bell
Old 25th August 2009, 09:08 PM   #19
tubee's Avatar
Well i have done all work right, the Sony is revived again after so many years.
Daisy Bell
Old 25th August 2009, 10:28 PM   #20
Banned
tubee,
congratulations.
Of course.
A different brand should do as well, the higher capacitance the better.
Need 2SC1963(1962) and 2SA835 tubee Solid State 2 23rd June 2009 03:27 AM
Does anyone know the pinout of AES/EBU on XLR ? Johnix Digital Source 1 15th July 2008 05:19 PM
Different pinout for the same BJT alfaudio Solid State 3 29th June 2007 03:27 PM
help with pinout karma Tubes / Valves 15 14th May 2003 11:05 PM
Copyright ©1999-2013 diyAudio
