I have a Leak stereo 70 which cuts out on the left chanel between 12 oclock and 1 oclock. If I reduce the volume a fraction, or increase it a fraction it is fine, it cuts out on the left chanel only, it just goes dead. When turning the volume up and down quickly there is a faint crackling on the left chanel when its dead, otherwise it sounds superb. I have my cd player running through the tape monitor switch to take the tone controls out of the loop too. Any ideas ?
#2 |
Change your Volume potentiometer
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
or clean it
#4 |
Thanks for the replies, Is it easy to clean the potentioneter, im imagining that it is some kind of circular track on the Leak 70 with fingers that run across it, would that be correct ?
#5 | |
I tend to replace them as they quickly become faulty again if cleaned.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#6 |
If the pot is an open type, try spray WD40 into the pot.
And before everbody starts Used it on my old QUAD 34 pre 7 years ago, and there has never been a problem since (seems almost as a one time cure)
#7 | |
If the pot track is simply worn out then no amount of WD40 will fix it, it needs replacing. If some dust or hair has got under the wiper then WD40 will probably blow it out.
#8 | |
#9 | |
It's very rare for a pot to be worn out, and a quick squirt of WD almost always provides a long lasting cure. I had a Leak Stereo 70 for years, great amps - I only replaced it because I bought a three head cassette deck and it didn't work very well with it. Over the many years I had it, the Leak got used for disco's, guitar's, all sorts of things
Nigel Goodwin |
#10 | |
I run a mobile disco and the crossfader is being used for hours on end. This means they dont last long. This is why they are usually a module that be easily be replaced.
| Xindak attenuation for use with Leak Stereo 20, help please | camperman | Tubes / Valves | 15 | 20th May 2008 07:12 PM |
| Leak Stereo 20 clone? possibly with 6V6? | bikehorn | Tubes / Valves | 26 | 29th March 2007 01:52 AM |
| Leak stereo 70 fault | harrygrey382 | Solid State | 16 | 25th February 2007 04:07 PM |
| Leak Stereo 20 questions | Johan Potgieter | Tubes / Valves | 23 | 30th April 2006 11:57 PM |
| Mods on leak stereo 20 | bronto64 | Tubes / Valves | 22 | 26th April 2004 08:27 PM |
| Page generated in 0.12504 seconds (73.63% PHP - 26.37% MySQL) with 10 queries |
