#11 |
Well, I've found a solution to my problem, I'll just bi-amp and use two LM3886's per channel, still powering 4ohms but gives me more power. Everyone's been telling me to bi-amp anyways...
#12 | |
Warp Engineer
On Holiday
#13 |
But with peltiers they also produce heat of their own. And you need one rated higher then the wattage of heat you intend to move. They're rather inefficient.
You'd only use a peltier to cool something below ambient. Because whatever you'd use to cool the peltier would cool whatever you want to cool, down to pretty near ambient anyways. Even in CPU overclocking peltiers don't have many uses. Try dissipating 300w+ of heat from from a computer... |
#14 |
Warp Engineer
On Holiday
Yes i understand that ... but they do have their uses ... and below ambient is nice but then humidity becomes a problem ... its just a matter of which compromise you prefer.
#15 |
Yeah peltiers are just used for overclocking, it may improve the sound I guess, by producing a steady temperature, but peltiers introduce their own problems. E.g condensation, you have to insulate practically everything around the peltier, high heat on one side of the peltier, and watercooling the peltier, which is a huge problem by itself.
#16 |
A peltier wouldn't exactly produce a steady temperature. A rise in heat output of the device being cooled would result in a rise in heat being transfered from the cold side to the hot side of the peltier, therefore also increasing the amount of total heat having to be dissapated. While I may seem to be putting peltiers in a bad light, they do have their uses and are excessively usefull in some applications. They do for one work rather well if you ever intend to build a DIY mini-fridge
#17 | |
www.sound.au.com If you already have 4-ohm speakers, fine, but if you haven't got them yet check the 3886 specs carefully. Depending on your supply voltage and heat sinks, you might actually get more power into an 8-ohm load. |
#18 |
Ya, I'm aware of it's output into 4 and 8 ohm speakers. But I already have my speakers built, it was my previous project, now the amp comes secound.
| Transformers for LM3875 and easy load | Frode | Chip Amps | 3 | 15th December 2007 03:16 PM |
| LM3876 newbie question | david90 | Chip Amps | 3 | 17th July 2005 04:23 PM |
| LM3876 vs. LM3875 | Wynand | Chip Amps | 3 | 12th July 2005 09:03 PM |
| Is LM3875 better tham LM3876 | goldyrathore | Solid State | 12 | 12th July 2005 08:53 PM |
| Heater winding load question. | G | Tubes / Valves | 3 | 22nd May 2004 06:40 PM |
