Class-A-Burn: an amp with capacitive feedback divider around MOSFET
Old 27th August 2009, 07:58 PM   #31
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by Bigun View Post
Still learning....
The latest schematic shows no d.c. path to the gate of the lower MOSFET. Yet it has to be biassed. Is it self-biassing ?
R4
R3 and R5 provide negative feedback by DC current stabilizing working point on the level defined by voltage divider of regulated bials voltage.
Old 27th August 2009, 09:05 PM   #32
Bigun is offline Bigun  Canada
Bigun's Avatar
OK I see it, the output from the Opamp provides the dc biass for the gate of the MOSFET. So you have global resistive feedback and the MOSFET has local capacitive feedback.
So in terms of overall compensation, does C1 or C4 represent Cdom or "how does the compensation work" ?
Old 27th August 2009, 11:17 PM   #33
kenpeter is offline kenpeter  United States
Does it matter that feedback caps aren't non-linear in the quite same way
as the gate? Is gate lead or feedback path inductance of any significance?
Old 27th August 2009, 11:53 PM   #34
Wavebourn's Avatar
Capacitive feedbacks by voltage in each stage on AC, and DC servo by quiescent current.
No, for compensation resistors in series with feedback cap only for MOSFET ("gate stopper"), the OpAmp is already unity gain stable, inside.
In the quite same way?
Are you kidding, Peter?
Old 28th August 2009, 12:40 AM   #35
Wavebourn's Avatar
Let me guess Peter: are you thinking currently of the way to create an Anti-Varactor?
Old 30th August 2009, 08:41 AM   #36
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Wavebourn,
The world is not perfect!
Certainly not, and you are making it even less perfect.
Now I`m only paying attention to the reverse transfer capacitance, which is a substantial cause of amplifying device nonlinearity. Suffering from voltage amplification, its value can easily change by a factor of 100. While introducing feedback, the signal voltages are effectively shorted out, restricting the bandwidth.
Crss for IRFP054 is 300pF specified @ Vds 25 and 1MHz, now expanded with 10000pF (for comparable laterals 8-10pF @10Vds, 1MHz). This is not the way to achieve linearity, regardless what you get in simulation. Manufacturers and designers desperately try to keep the parasitic capacitances small, as they severely degrade the performance in every application.
Class-A-Burn: an amp with capacitive feedback divider around MOSFETHide this!Advertise here!
SE J/MOSFET Class A Amp, no Feedback widowmaker Solid State 5 11th July 2013 07:38 PM
Resistor values in feedback loop/voltage divider??? vynuhl.addict Solid State 29 13th February 2007 03:05 PM
Capacitive feedback, anyone tried this? scott wurcer Solid State 22 3rd February 2007 12:57 AM
New capacitive motional feedback method Nuutti Multi-Way 31 14th March 2006 03:04 AM
Mosfet class A p/p amp... is feedback required? nobody special Solid State 13 11th September 2004 07:30 PM
