Class-A-Burn: an amp with capacitive feedback divider around MOSFET - Page 3 - diyAudio
Old 24th August 2009, 03:49 AM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Lumba Ogir View Post
Wavebourn,
tell me very confidentially, why extend the already huge and extremely harmful internal capacitances? What are they supposed to divide?
I don't get it either... so I'll try to guess. Looking at the simplified schematic in post 15
C3 samples the output to the top device, like Nelson's 'modulated Cascode' for better linearity ???
C1 bootstraps the gate capacitance on the output device so that it's no longer signal-dependent ???
are we seeing here the 'Wavebourn Tower' perhaps...
Old 24th August 2009, 04:02 AM   #22
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
No, it's not a 'Wavebourn Tower'. It's a crazy idea about vacuumless triode, made of a MOSFET with capacitive voltage divider in feedback.
Lumba, I don't extend already huge and extremely harmful internal capacitances. I just shunt them by external capacitances that are useful.
Old 24th August 2009, 05:30 AM   #23
Wavebourn's Avatar
Here is a better version, with idle current trimpot. Still, needs some gate stoppers.
Old 25th August 2009, 07:54 PM   #24
Wavebourn's Avatar
This version of PIM-free amp can be driven by a line out of a player.
Old 26th August 2009, 03:42 AM   #25
Wavebourn's Avatar
Finally, I've found the way to fit in gate stoppers so they won't screw up everything.
Old 27th August 2009, 01:42 AM   #26
Bigun's Avatar
You have to consider me electronics illiterate - I've just started to read the Zen articles and am getting a little bit more comfortable with MOSFETs etc. I amy even build a Zen amp next. So, since your circuit looks similar to Zen I'd like to understand the benefits of your capacitive divider - can you explain a bit more about it using the Zen amp as a comparison ???
While I have you here - I remember reading your comments on a hybrid output device where you have a BJT with heavy emitter degeneration in parallel with a MOSFET and you called it 'the perfect device' - what are it's benefits, perhaps it's a candidate for a Zen amp design too ???
Old 27th August 2009, 03:43 AM   #27
Wavebourn's Avatar
The problem is, I still can't find neither perfect device, nor perfect usage for non-perfect devices.
What is the difference between this amp ant the rest of them, in usage of capacitors for feedback.
MOSFET has big capacitances. If to use resistors in feedback there will be always phase shift between currents flowing through this resistors to MOSFET's gate and a voltage that is created on the gate, that controls the MOSFET. That means, feedback will be always shifted by phase. Since that capacitances are non-linear there is non-linear modulation of the complex transfer function, and it is frequency dependent.
If to use capacitors for a feedback divider, it would be frequency independent, and there will be no phase shifts between feedback current and voltage.
Now we have a stage with capacitive input impedance, it is a new problem we created solving the previous one.
The world is not perfect!
Old 27th August 2009, 12:34 PM   #28
Bigun's Avatar
thanks - it makes sense now. I see what you are hoping to achieve. Would it be correct to say that the feedback phase shifts are going to be more of a problem at high frequencies, so your proposal benefits these frequencies the most ? And, isn't the input impedance capacitive anyway with a MOSFETs ?
Old 27th August 2009, 04:13 PM   #29
Wavebourn's Avatar
Exactly.
Old 27th August 2009, 06:49 PM   #30
Bigun's Avatar
Still learning....
The latest schematic shows no d.c. path to the gate of the lower MOSFET. Yet it has to be biassed. Is it self-biassing ?
SE J/MOSFET Class A Amp, no Feedback widowmaker Solid State 5 11th July 2013 06:38 PM
Resistor values in feedback loop/voltage divider??? vynuhl.addict Solid State 29 13th February 2007 02:05 PM
Capacitive feedback, anyone tried this? scott wurcer Solid State 22 2nd February 2007 11:57 PM
New capacitive motional feedback method Nuutti Multi-Way 31 14th March 2006 02:04 AM
Mosfet class A p/p amp... is feedback required? nobody special Solid State 13 11th September 2004 06:30 PM
Copyright 1999-2017 diyAudio
