Krell KSA 100 schematic, resistor value question - Page 3 - diyAudio
Old 19th February 2004, 01:00 PM   #21
Tube_Dude's Avatar
Originally posted by millwood
I thought it was settled on that other thread that for such a topology, you cannot calculate VAS and LTP current. Assuming that the current in the LTP legs is evenly split is falwed.
hopefully, the time and effort there were not wasted.
The time and effort were never wasted in good company!!!
Were your simulation is flawed is:
The bases of the input LTP are not grounded in the real circuits...(i prefer real circuits that simulated ones)...and in the case of the Krell they are connected to ground by a 22 KOhm resistor.
This is reflected in the emmiters of the LTP as as 220 Ohms + the 220 Ohms emmiters resistor ..become 440 Ohms...
So any small diference in the Vbe of the LTP become with no consequence!!!..and the current will be splited almost evenly in the LTP.
Jorge
Old 19th February 2004, 01:05 PM   #22
Account Disabled
someone had pointed out in the other thread that none of the above will change the nature of the circuitry: it is not determinate, "almost evenly" notwithstanding,
Old 19th February 2004, 01:13 PM   #23
Tube_Dude's Avatar
Default A lucky bias...
So your conclusion!!!
The bias in the krell is indeterminated!!
Is set by luck!!
Jorge
Old 19th February 2004, 03:06 PM   #24
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
millwood :
I recommend you throw some transistors at a breadboard and test by yourself this biasing scheme in an empirical way
Anyway, this topology is reliable since it's the one choosen for most consumer discrete amplifier circuits today
Old 19th February 2004, 04:04 PM   #25
Banned
Send a message via Yahoo to Elso Kwak
Default Bias Circuit
Hi Millwood,
I see an amplified diode or VBE multiplier as in Ritchies book: Transistor Circuit Techniques, Chapman & Hall, page 160.
Not determinate?????
Old 19th February 2004, 04:09 PM   #26
Tube_Dude's Avatar
Default Re: Bias Circuit
Originally posted by Elso Kwak
Hi Millwood,
Sorry...i'm not Millwood...but he talk about the current in the VAS stage...and the VBE determine the current in the output stage...
Jorge
Old 19th February 2004, 04:32 PM   #27
Account Disabled
it is not determinate because you cannot calculate it without assuming the current going through at least one leg of the LTP, or vis versa.
that's why simulated results are so widely apart from each other. I was hoping that service manual will have specified the current so we know for sure what it is.
Old 20th February 2004, 01:59 AM   #28
MikeW is offline MikeW  United States
MikeW's Avatar
Question bias?
Has anyone built one of these and measured the bias?
MikeW
Old 20th February 2004, 03:44 AM   #29
jcx is offline jcx  United States
the point of the uastable VAS current thread applies with current mirrors in the complementary diff pair collectors - the high output impedance provides a very large voltage gain at the input to the vas which results in a unstable voltage into the vas and indeterminate vas bais current due to the lack of common mode feedback, differential feedback still holds the current division ratio in the diff pairs close to 1:1
in this circuit the 1KOhm resistive collector load provides a very definite and calcuable voltage into the vas and hence a predictable vas bias current (counting on my thumbs i get ~6 mA)
with a dc bolcking feedback cap for unity dc gain, dc emitter degeneration and offset trim i think the assumption of equal current division in the diff pairs is pretty good
the diff pair current sources could be greatly improved with a couple of bootstrap resistors, the diff pair bypass and feedback dc blocking caps should all be nonpolar/bipolar electrolytics with as high a voltage rating as you are willing to fit
KRELL KAV 300I Schematic Anyone ? vdavidov Solid State 10 5th December 2011 02:15 PM
Need a krell 300i amp schematic soundcrafters Solid State 47 4th November 2007 11:15 PM
seeking krell krs-200 schematic james559 Solid State 5 5th September 2006 02:55 AM
Need KRELL PAM-1 Schematic HELP ! Audiofanatic Solid State 0 7th March 2003 06:04 PM
Copyright 1999-2017 diyAudio
