Having fun with a PIC16F84A microcontroller
Old 13th August 2009, 02:45 AM   #1
iko is offline iko  Canada
iko's Avatar
Default Having fun with a PIC16F84A microcontroller
I'm planning to use a PIC16F84A microcontroller to keep the shunt current within a certain range, in a shunt voltage regulator. The regulator I have in mind is the salas simplistic that can be found in this thread
http://www.diyaudio.com/forums/showt...5&pagenumber=1
I've started to put together a page with some info about the pic chip, just in case other people might be interested.
The page is found at this link , and is very much work in progress.
More details to come, stay tuned.
Old 13th August 2009, 03:01 AM   #2
Tham is offline Tham  Malaysia
Love to hear that I may soon be able to remove the big heatsink from the high current shunt regulator. Again I volunteer to build the first one .
Old 13th August 2009, 03:07 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi ikoflexer,
Thank you very much for this!!
I will be watching and reading. I do have a PIC16F84A on hand already.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 13th August 2009, 03:24 AM   #4
jkeny is offline jkeny  Ireland
Banned
Great start, Iko. Can you say anything about how this will work, what the concepts behind it are? However, I don't mean to start an endless stream of requests for functions, in fact, I believe it should be kept tight & minimal, especially as it will be a first uc project for lots of us
Thanks for kicking this off - I'm sure we'll see this thread mushroom into many pages
Old 13th August 2009, 03:26 AM   #5
jameshillj is offline jameshillj  Australia
.... "pic" controlled, shunt reg, high current, power supply - grabs your attention - this's something 'right out da box' - definitely not so simple now!
Maybe a "Salas 'minI pic' shunt reg"!
Will follow, with interest - very far behind, unfortunately!
Old 13th August 2009, 03:42 AM   #6
iko's Avatar
Thank you guys.
Here's the spiel, and I'm just thinking out loud here. The pic I'm looking at has a total of 13 I/O bi-directional pins. We can set a few pins to be inputs, and a few to be outputs. Using some kind of a resistor ladder the input will be a simple A/D converter, converting the voltage across a resistor sensing the shunt current to a few zeros/ones which will be fed to the pic. The pic makes a decision to decrease or increase the shunt current, and it puts a code of zeros/ones on its output pins, which will now be converted by a simple DAC (can also be a resistor ladder thingy, maybe) to a voltage, used to increase/decrease the value of a voltage controlled resistor (mosfet?) which in turns controls the shunt current. I'd like to keep it as simple as possible.
Old 13th August 2009, 03:59 AM   #7
astouffer is offline astouffer  United States
astouffer's Avatar
No need for a DAC or anything fancy. Look at the chips with PWM modules built in. Feed the PWM signal into a low pass RC filter and you'll see a DC voltage.
The PIC16F84 is a pretty limited. A 16F684 or 16F628A is a good starting point.
Old 13th August 2009, 05:25 AM   #8
iko's Avatar
Thanks! I already looked at the 16f628a because it has an internal oscillator so, fewer outside parts. But didn't think to of using the pwm module. I was also considering the 16F716 which besides the pwm module has an A/D module too. This is all very new to me...
Old 20th August 2009, 11:15 AM   #9
Nigel Goodwin is offline Nigel Goodwin  England
The 16F84 was obselete last century, replaced by the 16F628 - however, due to demand for an old part (why?) they reintroduced it at a higher price. You certainly shouldn't be using a 16F84 these days, and even worse not writing a tutorial using one, you're just prolonging people using it - use a modern device, cheaper, higher spec, and easier to use. The 16F84 is long dead, don't keep dragging it up.
For a regulator you really need (as a minimum) hardware PWM, and analogue inputs, this makes it trivial to make a regulator.
If you check the circuit and software for the PICKit2 (MicroChip programmer) they use hardware PWM and analogue feedback to create a 13V regulated supply from the 5V USB port voltage.
Nigel Goodwin
Having fun with a PIC16F84A microcontrollerHide this!Advertise here!
Microcontroller Help imix500 Parts 8 3rd September 2008 03:49 AM
help with microcontroller sss Everything Else 2 31st July 2008 05:30 PM
FLAC on microcontroller gene_klein Digital Source 4 1st December 2007 03:44 PM
microcontroller programming traf Digital Source 7 12th September 2007 01:49 PM
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 07:12 PM
Copyright ©1999-2017 diyAudio
