Hi.
I recently bought an well used Denon pma-1080. But i have some problems. The output is cut off after a few minutes when started from cold. If I change inputs i can clearly hear that the relays doesn't click as they should. I can also blow into the cabinet left side, behind the transformer and it gets back on. But if I switch off/on a few times, the amplifier can be ok for the rest of the day. Do anyone have service manual for this amp. or suggestions in where to start looking for error.. best regards Andreas |
#2 |
check for cracked solder joints
#3 |
Hi.
I've checked for solder cracks, and found a few.. But the problem is still present.. there are some resistors that get hot on the relay-board for the outputs, and those had cracked slodering. And the board also had evidence from liquid spills.. Do anyone have some schematics for this amp, or a closely related amp? i.e PMA 980R ?? Or where can I get one? Best regards Andreas |
#4 |
Maybe the relays are bad.
Measure the power to the relays. I have 2 denons on is a 980r but i only had a output transistor problem on that one. Alot of old Marantz from the same time era got relay problems. I have just bought a defective pma-1560 which turns itself off ,clicks when you try to turn it on. I will receive this amp early next week and maybe i can give you some idea to your problem. Optical class A is great. Pelle |
#5 |
Hej Andreas,
Send mig en PM med din e-mail adresse. Jeg kan hjælpe med service-manualen og måske også med et par forslag til, hvad der kan være galt. Med venlig hilsen /tricomp |
#6 |
I have a PMA-1080R that I bought used some years ago, and I have had many problems with the relays.
First, the sound in the right channel faded away now and then. I found that the contacts in the output relay were burnt and measured tens of ohms when they were closed. Cleaning the contacts helped for a while, but later I just bypassed the output relays. Which of course disables the protection circuits and muting. I also had problems with Source Direct. The signal was lost in both channels, if I remember correctly. Never found the cause. I stopped using Source Direct. Mats. |
| Schematics of NAD 208 & Rotel 1080/1090 wanted! | Ultima Thule | Solid State | 30 | 30th August 2010 07:57 PM |
| Pioneer SX-1080 not working for sale | jeffshort2000 | Swap Meet | 0 | 24th November 2007 07:57 PM |
| popping crackling distortion that clears up after 2 mins Help!! | Puggie | Solid State | 7 | 11th October 2006 11:13 AM |
| 1st ever project finished 2 mins ago - IT PLAYS!! | gilbodavid | Class D | 7 | 3rd November 2005 09:32 PM |
| Page generated in 0.09472 seconds (66.81% PHP - 33.19% MySQL) with 10 queries |
