#31 |
Digital-Do-Main go to the trouble getting the devices made for them, their patents mention a company called SYSTEC KK as co-applicant.
Could be: Systec Research, Inc Some of their patents Dual Static Indution Transisitor in Adjacent Arrangement Within Chip & Power Amplifier Circuit for Audio Using the Same Push-Pull Using Static Indution Transisitor of the Same Conductive Type Current Setting Circuit of Power Amplifier Circuit Using Static Indution Transisitor And this might be of interest High Speed, High Voltage, and Energy Efficient Static Induction Devices Rgds James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson Last edited by tvi; 14th April 2010 at 06:47 AM. Reason: formating |
#32 | |
Anywhere a discrete op amp was created with same PCP surface sizes than a normal integrated version (somewhere here on the forum has been explicite reported, but I don't know the exactly title of the subject) Actually the same must be possible for the vintage V-FETs. The PA02 e.g. from Apex Precision Power offers IC's in a TO-3 like outline: http://www.cirrus.com/en/pubs/proDatasheet/PA02U_O.pdf I read here, that this are no monolitic versions but thickfilm-technology, that is similar to SMD PA02 pdf, PA02 description, PA02 datasheets, PA02 view ::: ALLDATASHEET ::: Some pics of this devices you will find by post #4 about Thick Film Hybrid (not monolithic) Integrated Circuit Amplifier - Overview If I order this Apex TO-Devices empty (i. e. without their thickfilm-PCB) and I have a circuit topology that create the right character so as appropriate power SMD FETs for solder on the TO3 die surface to get the typical V-FET Characteristic by higher realibility at the same time, then I have a good solution. Ideal must be a jFET from Lovoltech together with cascode MOSFET/IGBT, but a commonly power MOSFET (even enhanced mode version) with Sziklai cascode consists of small signal 2SK170 jFET & BjT + BjT HV cascode transistor must us also bring to the wished targed function. All the other possibilities have the disadvantage, that the Sony devices are hard to find and if I have success, I get still used devices. Last edited by tiefbassuebertr; 31st May 2010 at 06:09 PM. |
#33 |
The one and only
I have been playing with some of these parts. When you
talk about using or emulating them, the key question is "What characteristic of the Vfets or SITs is of greatest interest to you? For me, it is the characteristic of the output (Drain) conductance.
#34 | |
I would generally prefer that characteristic, that makes at one hand expect nearly the same distortion behavior, but at other hand the least possible change in the amplifier topology itself (concerning the model, which is to repair). The fact, whether the threshold voltage (Vgs) is in the positive or - as in the original V-FET device - in the negative area is located, is less important. Much more important is an quite identical curvature of all transfer characteristic curves itself - this is the main challange - so I think. Last edited by tiefbassuebertr; 1st June 2010 at 08:07 AM. |
#35 |
about
New SONY V-Fet reliability problem discovered ! - AudioKarma.org Home Audio Stereo Discussion Forums I read by last post #19 from "Mr. V-FET" follow (written five years ago): V-Fet emulation: I worked on that for a while and I found that it is possible to bring a 150W V-Fet emulating circuit (including a MOSFET as power device) completely into a TO-3 can. But the end price for such a device would end up at perhaps 50$ per piece at 1000 pcs. Who would be willing to pay such a price for a 150W transistor ? |
#36 |
I would if they would be closely matched by production.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#37 | |
Densen amp to look his profile |
#38 | |
First taste of Papa's new devices The brand "Power Integrations Inc" about http://www.powerint.com/en/design-su...lication-notes is able to create intelligent MOSFET's like follow example for switching applications: http://www.datasheetcatalog.org/data...int/TOP202.pdf This means for me, that this brand is probably also able to introduce intelligent V-FET's, suited as improved successors for all V-FET's from Sony, NEC and Yamaha, but with very enhanced reliability in all respects. In opposite to the old ones there must be a "built in" protection. The question is only, which quantities for order are at least necessary so as wich flate rate costs for the singular developement costs. Last edited by tiefbassuebertr; 18th September 2011 at 09:18 AM. |
#39 |
Hitachi's HA-500f employed 2sj20/2sk70 too.
HA-500f is more rarer than sansui's one even in japan. I have gotten and maintained it but sold at auction yet. Hitachi discontinued V-FET soon because they invented famous MOS-FET 2SJ50 2SK135 series... |
#40 | |
Lo-D HA-500F http://audio-heritage.jp/LO-D/amp/ha-500f.html http://www.niji.or.jp/home/k-nisi/ha-500f.html http://www.hifidiy.net/index.php?act...ead-tid-337714 http://www.real-audio.ru/measurements/shop/s-amp.html Last edited by tiefbassuebertr; 21st September 2011 at 12:04 PM. |
| WTB: 2sk60, 2sj18 | cartman | Swap Meet | 6 | 30th November 2010 08:25 AM |
| VFET for SONY TA-F7 2sj18 and 2sk60 | ioschi2003 | Parts | 1 | 31st March 2009 03:35 PM |
| Sony CDP502ESII vs Yamaha CDX-993 | torque018 | Digital Source | 1 | 27th October 2008 10:44 PM |
| Buy: tranzistor 2sk60 & 2sj18 | kidoo | Parts | 1 | 26th April 2008 01:21 PM |
