#11 |
Banned
tiefbassuebertr,
please get it right, there are no successor devices. I would try to replace them with lateral MOSFETs. |
#12 | |
Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2 transistor kits |
#13 |
Banned
Hannes,
what would you do? |
#14 |
Since SITransistors have Mu, might attempt replacing them with
a Triodlington arrangement of Vacuum Triode + Bipolar? Cathode to Base, with Plate and Collector tied together. Though it might be difficult finding a Triode that doesn't leak too much at the grid when the plate voltage is drawn extremely low... The idea that the triode provides tight local 1/(Mu-1) feedback of collector voltage to the base... Thus the collector inherits the triode's voltgage linearity. If there is a small signal version of SIT or V-Fet (perhaps for RF?) you might fudge some sort of a SITlington for similar inheritance the rule of Mu to a power bipolar device... The bipolar mentioned above, could just as well be enhancement MOSFET, with a bleed resistor from gate to source... Its just there to amplify current, Voltage gain linearized by the watchful eye of Mu. |
#15 | ||
And even if you did, chances are that some of the tons of other transistors in that amp also die at some point Quote:
Have fun, Hannes
#16 |
Banned
Hannes,
I was not aware of the details, see a simpler design below, lateral MOSFETs can be biased conveniently (with a resistor). |
#17 |
Where do you have this circlotron from?
#18 |
Banned
From a Japanese site, I don`t have the link, was having minor difficulty following the description.
#19 |
You sure the power supply belongs to that circuit? In the schematic V1+V4 read as 30V, but are clearly voltage doublers (60V) in the psu-schematic. Have fun, Hannes
#20 |
Banned
It should, lying in the same folder here...
| WTB: 2sk60, 2sj18 | cartman | Swap Meet | 6 | 30th November 2010 08:25 AM |
| VFET for SONY TA-F7 2sj18 and 2sk60 | ioschi2003 | Parts | 1 | 31st March 2009 03:35 PM |
| Sony CDP502ESII vs Yamaha CDX-993 | torque018 | Digital Source | 1 | 27th October 2008 10:44 PM |
| Buy: tranzistor 2sk60 & 2sj18 | kidoo | Parts | 1 | 26th April 2008 01:21 PM |
