Another Yamaha C-80 problem
Old 9th August 2009, 03:09 AM   #1
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Default Another Yamaha C-80 problem
I just went to turn the volume down ( yes I know but the wife sort of insisted ) and I got a shock when my fingers touched the volume knob.
I have of course switched off and disconnected, opened the case and my untrained eye can see no bare wires or anything obvious.
Any thoughts or comments??
I like the phono stage and Parametric EQ in this model so don't want to change, also we just committed to buy a house so the money for a new pre-amp isn't there.
As you can see from my avatar we are now in Geelong so my old tech-weenie friends are elsewhere and too far away
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 9th August 2009, 09:41 AM   #2
col is offline col  Australia
col's Avatar
sure it wasn't just a static shock from your body discharging touching the(grounded) volume knob? Are your floors carpeted, what material are your shoe soles made of?
col.
http://www.minirig.org.au
Old 9th August 2009, 10:24 AM   #3
Moondog55's Avatar
Is that possible with double insulated cases??
You know I never even thought of that, maybe I am looking at worst case scenarios, I was wearing my new Croc slippers and it is wool carpet
Old 9th August 2009, 10:50 AM   #4
col's Avatar
Somebody please correct me if I'm wrong. Usually, anything that is metallic and is exposed has to go to the ground pin on the power socket. So if your Yamaha has an aluminium volume knob......
is there a URL for those croc slippers?
edit: http://www.fatshoesday.co.uk/images/crocs mammoth.jpg
col.
Old 9th August 2009, 10:50 PM   #5
Moondog55's Avatar
Hey Col that link is 404
Maybe I was panicking a little, while the top is off the case I'll now do the replacement of the storage caps as they are all showing signs of bulging.
I noticed that the wires leaving the entry point and leading to the power switch on the front panel are not themselves insulated any further than the PVC sheath and are not twisted together.
Query ? Should I twist them and get some cover tubing for the 240V mains wires?
Also can anyone tell me why Yamaha didn't fuse this pre-amp? And should I do that, fit a fuse I mean??
Old 9th August 2009, 11:19 PM   #6
eyoung is offline eyoung  United States
eyoung's Avatar
Hola Y'all...
Is the power cable 2 prong or 3 prong... some older hi fi had 2 prong non polarized plugs ...
regards, Elwood
"Lead me not into temptation...I can find it myself."
Old 9th August 2009, 11:26 PM   #7
Moondog55's Avatar
Australian 2-prong plug; 2-core cable no safety earth wire .
Not an IEC connection; cable goes thru a plastic gland
Old 10th August 2009, 12:15 AM   #8
col's Avatar
how about a photo of the insides?
col.
Old 10th August 2009, 02:13 AM   #9
Moondog55's Avatar
OK here are Flickr links
http://farm3.static.flickr.com/2601/...f552817565.jpg
http://farm4.static.flickr.com/3544/...b7ddd8eec8.jpg
http://farm4.static.flickr.com/3594/...f0a8cc2336.jpg
http://farm4.static.flickr.com/3507/...e21ffe8f61.jpg
http://farm3.static.flickr.com/2639/...22eef5109c.jpg
Old 11th August 2009, 03:35 PM   #10
ekidnah09 is offline ekidnah09  Australia
moondog,
Is your house supply fitted with a safety switch or sometimes called an RCD (residual current device) this is at your meter box switchboard?
The safety switch if fitted would of tripped your supply off if the ac was live and you touched the case, providing the zap was over the tripping current which is very low (I think 50mA). This is the current that flows through your body to ground the safety switch picks this up and trips off the supply.
If you have a multimeter check resistance between each of the ac prongs and the case to be sure there are no shorts to the case the resistance must be infinity.
If in any doubt get the item electrically tested by a qualified electrican.
You might get him to install an IDE socket that way you can install an earth. There are also IDE socket power filters if you have room. Jaycar sells one for under $10.
While you are replacing the power caps I would insulate any exposed 240v wiring with heat shrink, PVC tube or PVC tape. I hope this helps remember any doubts and get it electrically tested. As you like the unit it will not cost a lot to fix if it has a problem that is. By the way have you thought about replacing the doides with Schottkys. Good luck
Another Yamaha C-80 problemHide this!Advertise here!
Help! Yamaha CDX-993 problem. Pete22 Digital Source 15 3rd April 2016 07:51 PM
Yamaha C-4 Muting problem Notorious Solid State 3 15th July 2012 12:28 PM
Yamaha C-80 preamp problem Moondog55 Solid State 35 14th September 2010 07:05 AM
Yamaha RX-797 problem...opinions? bmwscoot Solid State 8 14th June 2009 10:12 PM
Yamaha B-1 Problem aged one Solid State 4 2nd November 2004 01:20 PM
Copyright ©1999-2017 diyAudio
