Old 7th August 2009, 07:17 PM   #1
Brit01 is offline Brit01  United Kingdom
Default Cracking sound from amp - help
Hi guys,
Getting an occasional worrying crack/pop noise coming through my amp maybe once or twice an evening. Just on left channel.
It's a 1992 Carver TFM-55. One of the rails has been replaced with new power transistors (before I bought it).
Since then I've replaced most of the power caps, some differential transistors and some resistors.
Sounds very good with the new parts but bit worried now.
Maybe a sign of one of a power transistor going?
Or maybe an old mylar cap going?
Or some old Carbon Comp. resistors?
Old 8th August 2009, 03:47 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Or a bad solder
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 8th August 2009, 04:07 AM   #3
keantoken's Avatar
Default Re: Cracking sound from amp - help
Originally posted by Brit01
Hi guys,
Does sound like maybe some solder/connection coming loose because of thermal expansion (possibly of the new output devices - could have been a bad solder job).
- keantoken
Old 8th August 2009, 04:17 AM   #4
you may be right as it cracks loudly after warming up some 30 minutes.
Now the issue is where. Narrowed down to the right channel at least and I'm very familiar with the circuit as I've worked on it a great deal.
I'll be replacing some diodes and resistors in a few weeks so I'll give it a good look over.
Old 8th August 2009, 09:58 AM   #5
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Check for any DC excursions at the output
SivanandBalan
Old 8th August 2009, 01:13 PM   #6
djk is offline djk
djk's Avatar
"Or maybe an old mylar cap going?"
I suggest you replace the input coupling cap.
I've had the plating on the copperweld leads fail and it acts as you described.
Do not try an re-solder the original, replace it.
"Or some old Carbon Comp. resistors?"
They're carbon film type, and they can have the same copperweld lead issue. I would replace them too.
I would also replace the bias pot. If it goes open for an instant there will be a loud crack, and you could blow the amp and your speakers.
Candidates for the Darwin Award should not read this author.
Cracking/Static in Pre-Amp TheVille Solid State 2 17th April 2009 07:42 PM
Zenith K731 AM/FM radio audio random cracking sound in FM mode AC439 Tubes / Valves 15 20th February 2009 09:06 PM
A problem of cracking sound amp gaetan8888 Solid State 15 8th July 2007 07:41 PM
Cracking sound through speakers. magpietim Tubes / Valves 5 23rd October 2005 03:53 PM
cracking noise in P3a PetarLD Solid State 0 13th May 2004 04:03 AM
Page generated in 0.10006 seconds (75.35% PHP - 24.65% MySQL) with 10 queries
