Old 7th August 2009, 07:08 PM   #1
Unhappy Marantz pm66se
I've got a Marantz PM66SE. I've blown the internal fuse (admittedly by turning it up too loud!). I bought an identical replacement (1.6A 250V quickblow) and it goes pop as soon as you turn the power on.
At first glance there isn't any other components that are completely black or clearly bust.
Any ideas where I should go from here?
thanks
Paul
Old 7th August 2009, 07:26 PM   #2
tiefbassuebertr's Avatar
I would check first the power devices of output stage so as the driver transistors. If there are no fault, remove the power amp from the power supply and check your power supply separately.
Either the power supply has a short (if the internal fuse blown again) or the fault comes from the rest of the power amplifier (if the internal fuse don't blown again)
Marantz PM66SE Brian_x Solid State 109 16th March 2012 11:04 PM
Marantz PM66SE Question dark0n3 Solid State 16 27th April 2007 11:23 PM
Marantz PM66SE mods? insomniac Solid State 0 22nd June 2004 12:22 PM
Page generated in 0.06920 seconds (65.24% PHP - 34.76% MySQL) with 10 queries
