Krell KSA 150 transformer
Old 3rd September 2009, 07:19 PM   #11
Arick is offline Arick  Canada
Arick's Avatar
Hi everyone, I finally got the info through a friend, thank you to all for the help
Old 4th September 2009, 12:37 PM   #12
R.I.P.
if the KSA150 is a two channel ClassA amplifier, then Rocket has seriously underestimated the transformer VA rating required to power the output stages.
3.25A per supply lead for a two channel amplifier requires a continuous DC current of 6.5Adc from the PSU.
The minimum AC rating of the transformer must be at least double this i.e. Irms >=13Aac.
However, this will run the transformer at maximum temperature and will reduce it's life/reliability considerably. The exception here is if the transformer is designed for low regulation rather than to maximum temperature. I think Krell specified some/all of their transformers for low regulation, making temperature much less of an issue.
I would recommend doubling this again for continuous duty i.e. 26Aac for a two channel ClassA amplifier biased to 3.25Adc/channel. This will be BIG, HEAVY and EXPENSIVE.
Let's hope the KSA150 is a ClassAB amplifier.
regards Andrew T.
Old 3rd June 2016, 09:44 AM   #13
williamsdr is offline williamsdr
Exclamation KSA-150 Transformer specs? Dead - but not buried
Would you be willing to share the specs and a suitable manufacturer for the replacement transformer?
I also have a dead KSA-150 in need of a replacement transformer (among other things).
| know this thread has aged. I'm hoping you're still following|
Krell KSA 150 transformerHide this!Advertise here!
FS - Krell KSA 50 PCB & Transformer... Guiness Swap Meet 1 28th January 2009 11:39 PM
Audiophile transformer for Krell DAC-studio gto127 Digital Source 5 20th January 2008 08:04 PM
Voltage from the power transformer in a Krell KMA-100 mk1 Pinhead Solid State 5 29th April 2004 09:20 PM
