Old 7th August 2009, 04:50 AM   #1
Default nal Microphone Preamplifier IProfessioNA217 - My Project
Hello everyone,
I built preamp system with INA217 like in the picture. For now it is only a model on large universal plate but it's working very good!
I want to do the dual-layer PCB and put it in the chassis. I have only space for 154x90mm and I want to place the capacitors C1, C2, C8, C10, C12, C13 on the bottom layer in horizontal position. This capacitors are filters for voltage supply. Is this a good idea? whether the filtration will be good? On the top layer I want to put the transformers and underneath them the capacitors.
Anybody have a solution?
Best regards!
G
Old 7th August 2009, 11:32 PM   #2
Zero D is offline Zero D  United Kingdom
Yes the voltage rails should be very smooth.
It's much better to keep the transformer and smoothing caps as far away from the audio as possible. If you can, seperate these and isolate with a metal screening panel from everything else.
There is an error in the circuit diagram, please see my screenie to correct it.
All the best with it, and come back and let us know how it turns out.
elektor 'valve preamplifier' project fermatsEnigma Elektor 1 8th January 2008 04:41 PM
My tube preamplifier project thomsva Tubes / Valves 1 30th May 2007 12:03 AM
DIY Tube Microphone preamplifier gyraf Tubes / Valves 1 11th February 2003 01:12 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
Page generated in 0.06607 seconds (70.28% PHP - 29.72% MySQL) with 10 queries
