#21 |
tiefbassuebertr
I think that when using NMOS only, one can pull out all the tube topologies out of the box. |
#22 | |
Basicly it would be easy find out by the circlotron topology (= CSPP resp. PPP) without transformer (i. e. OTL) If you have an OTL circlotron tube power amp GM-20 (Graaf) and a finished MOSFET circlotron diy project at the same time, you can comparable both of them and tell about the results. I have heard both of them, but unfortunately not at the same time here a URL about MOSFET CSPP http://www.hinocatv.ne.jp/~s_suzuki/...OS/UHC-MOS.htm and two jpg's and a schematic about the GM-20: Last edited by tiefbassuebertr; 27th October 2009 at 02:27 PM. |
#23 | |
Distortion removal circuit and the automatic translation in English Google Übersetzer |
#24 | |
#25 |
another approach in this context
It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!! |
#26 |
can i suggest a serial dual differential ? it s balanced as
the phase spliting is naturally present in this topology... i would go this way if i had only one kind of power devices... |
#27 | |
URL collection of Totem Pole and CSPP (Single Ended related) Solid State Output Stage now there are additional topologies here on diyaudio, where used only N-Channel MOSFETs resp. only NPN BjTs: in the output power stage: 1) Circlomos from Elvee It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!! 2) Super-Pair Buffer from Linuxguru Low-distortion Super-pair Buffer simulation schematics 3) Kenpeter's follower - three in one (very special) go to post #47 about four transistor emitter follower (diamond buffer) as power output stage? 4) Class-B without crossover-distortion Class B w/o crossover distortion (1975) Number 2, 3 and 4 I haven't investigate, but it looks very interesting. If the author have found a method for reliability stabilizing of the idle current through the output for number 1, we have a very fine power amp topology. Last edited by tiefbassuebertr; 13th April 2010 at 02:11 PM. |
#28 |
I have the schematics of the Cabasses AM/AS1000 amplifiers which show class G output stage topology where the inner devices are N-channel MOS-FETs IRFP240, whereas the outer devices are complementary MOS-FETs IRFP9150/IRFP150, driven by a differential amplifier.
________________ Ce n'est pas se donner que de donner ce qu'on voudrait être. (Patrick Drevet) |
#29 |
#30 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| low audio on left channel jvc vn-300 | stevodude | Solid State | 6 | 19th April 2013 11:03 AM |
| 2SK343 & 2SJ99 Audio Mosfets, 140V, 8A | VS | Parts | 6 | 16th August 2010 08:26 AM |
| 16 channel Audio Playback | jiize | Digital Line Level | 1 | 26th February 2009 01:27 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| CD audio channel problem | gmonno | Digital Source | 0 | 5th July 2004 01:07 PM |
