Hello!
I've been searching for good class-A amplifiers for some time and found Nelson Pass' Zen, Pavel Macura's MPF and Rod Eliot's DoZ as the most popular three. I started with Zen and it really paid me well with it's apealing sound. Then I tried the MPF and found out that the bass is way better than Zen; the mid range and the highs felt same. Then I made the Doz and it gave me good mid and highs, but the bass was worse than the Zen! I made the DoZ exactly as displayed in the original article. I set the bias current of 2Amp for all three amps and the same capacitance multiplier 40V supply. Can anybody please tell me the reason behind the varying bass response of the three amps? Especially why it is so bad with Doz... Thanks.
LESS "THINGS", MORE LIFE |
#2 |
And i can tell you if you really want to face the truth. Will not publish as is not politically correct. Wanna know?.... will keep the answer to yourself? then write to: panzertoo@yahoo.com then you gonna know something about "human factor"... the "We factor" regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#3 |
are you using Fig5? C2 looks too small. To match C1, it needs to >=640uF try 680uF or even 1000uF. Note that fig4 has C2=470uF (for which he states bandwidth) and even that is too small. What value of C3 have you used?
regards Andrew T. |
#4 | |
Hi Andrew. Yes I'm using fig-5 and am using 220uF as C2 in DoZ and 4700uf for output(c3) coupling for all three amps. I too thought of C1 being too small and chose 4.7uF istead.
#5 |
C1=1uF looks about right with F-1dB~3Hz.
Changing C1 to 4.7uF and leaving C2=220uF is completely wrong. The amp will develop AC voltage across C2. that may explain why the bass sounds wrong/lacking/distorted. Try changing C1 back from 4u7F to 1uF and increase C2 from 220uF to 1000uF//1uF
regards Andrew T. |
#6 |
Subjective perception of bass is usually not much a question of low frequency corner, you may have DC - 50kHz amplifiers still sounding different in low frequencies. It is quite complex question, and I am afraid we still do not have right answers ...
#7 | |
Hi Andrew. Thanks for the suggestion. So the deficiency is in the design. Anyway I'm gonna try it with 1000uF as C2. With the original component values the article says the following Supply Voltage 40V Quiescent Current 1.7A Maximum power 8 Ohms 20W (15W) Output Noise (unweighted) <1 mV Distortion @ 1kHz, 15W < 0.2% Output Impedance 0.378 Ohm Frequency Response (-0.5dB @ 1W) <10Hz to >50kHz What's wrong with the last performance measure??
#8 |
try changing C2 to 1000uF and listen, then try changing C1 to 1uF and listen. Is there any difference? The 470uF and the 1uF are defining the low frequency bandwidth. That guarantees some AC voltage across the NFB capacitor. The input filter must set the bandwidth, not the NFB loop.
regards Andrew T. |
#9 | |
Are all three amps using similar power supplies and identical brands of capacitors?
Similar output impedance? Quote:
My opinion as well. Sometimes the perception of bass depends on the quality of reproduction of much higher frequencies. |
#10 |
Well I used the first track of Pink Floyd's Dark Side Of The Moon and watch the bass behaviour in a "no treable" environment... there are only heartbeats in the first 1 minute and they sound pretty "bassful" in my gainclones. So i thought they would be good for these amps too.
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Impedance of ESL varying with freq? | Pwoida | Planars & Exotics | 20 | 9th September 2005 06:37 PM |
| Has anyone compared the Chip amps against Class T amps? | soongsc | Chip Amps | 3 | 24th July 2005 11:50 AM |
| Page generated in 0.12798 seconds (80.83% PHP - 19.17% MySQL) with 10 queries |
