| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Thread Tools |
#11 |
So it's not actually needed, does it affect my DC offset?
#12 |
Never say never but no modern opamp I've tested has been much affected by asymmetric supplies, including offset. What you see at the output is controlled by the feedback values and bias currents. And maybe the signal
If only one supply is available you can create a resistive divider ground and buffer it- the "rail splitter" ICs, but a real ground between two supplies is far better from an impedance and stability POV.
What's in *your* junk box? |
| Thread Tools | |
| cmoy dc offset correction | magnade | Solid State | 0 | 5th August 2009 04:22 PM |
| cmoy help (DC offset) | erictooth | Chip Amps | 7 | 3rd July 2009 01:32 PM |
| DC Offset on the input of a Threshold SL10 | hifi-hospital | Solid State | 10 | 25th February 2007 09:26 AM |
| Question about DC offset from source. | theAnonymous1 | Solid State | 2 | 12th November 2006 08:07 PM |
| 36 V DC offset when source connected | revell | Chip Amps | 12 | 27th February 2005 08:29 PM |
| Page generated in 0.06242490 seconds (70.59% PHP - 29.41% MySQL) with 10 queries |
