Fast and precision current comparator
Old 4th August 2009, 09:37 PM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by darkfenriz
seriously current conveyor is a similar concept to operational amplifier, but it has two low impedance inputs and a high impedance output, nomen omen.
It has a intrisic speed, because there is no voltage gain inside.
Your patterns may work, but every transimpedance stage made around a resistor in negative feedback loop may have problems with stability.
It's because from 'voltage' point of view, input impedance is infinite, and resistance in feedbackloop is given, so the 'voltage' gain is below 1, which is something most opamps hate.
That's why I am going to use video opamps.
Are current conveyors available as ICs?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 4th August 2009, 09:46 PM   #22
Wavebourn's Avatar
This one looks better, for 20 mA input currents:
Old 4th August 2009, 10:01 PM   #23
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Actually i am not concious of any current convoyour IC.
edit: maybe you may use a current feedback amplifier with non-inverting input grouded
As for opamp stability, no opamp likes voltage gain below one, especially fast video opamps. A capacitor in feedback loop is often mandatory. I suggest you studdied circuits designed for fast photodiode amplifiers, they serve the same purpose which is converting current to voltage and there is much research there, for example on how to tailor feedback capacitor for macimum gain*bandwidth.
Old 4th August 2009, 10:08 PM   #24
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Wavebourn,
just like in audio, overall negative feedback is really a nuisance here.
Old 4th August 2009, 10:58 PM   #25
Wavebourn's Avatar
Originally posted by Lumba Ogir
Wavebourn,
Which overall negative feedback?
The first one is a current to voltage converter, with close to zero input resistance to prevent cross-talk between signals I measure.
The second one, is a maximum-possible-gain amp with logarythmic overdrive function; the 3'd one has a positive feedback, a flip-flop with well defined hysteresis to shape output and prevent oscillations.
Do you know what are you talking about, Lumba?
Old 5th August 2009, 06:06 AM   #26
PMA is offline PMA  Europe
PMA's Avatar
'Which overall negative feedback?'
That in the 1st opamp e.g., the I/V converter. The FB ratio is defined by Zol/R1
Old 5th August 2009, 07:35 AM   #27
Wavebourn's Avatar
Oh eah, Lumba spotted it right away! No good for audio!
Old 5th August 2009, 07:38 AM   #28
Wavebourn's Avatar
Like is drawn on my pictures?
Thanks!
Old 5th August 2009, 07:58 AM   #29
CraigBuckingham is offline CraigBuckingham
What you specified you want in the first post and what you are drawing don't seem to relate.
What exactly is the function required?
Old 5th August 2009, 08:12 AM   #30
Wavebourn's Avatar
I need to compare 2 currents when they flow in different directions, if to say strictly. Both may swing between -20 mA to +20 mA, up to 1 MHz frequency.
Fast and precision current comparatorHide this!Advertise here!
Precision Power PC2600.2 PPI over-current proteciont mikef1897 Car Audio 0 14th June 2006 10:02 AM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
comparator audio-kraut Solid State 8 15th November 2004 05:44 AM
Transistor Comparator ? thylantyr Solid State 9 9th April 2003 03:29 AM
