Old 3rd August 2009, 07:43 PM   #1
wleediy is offline wleediy  Singapore
Default high voltage regulator
I am now interested in regulator as even the serial reg do improve the amp sound.
In my friend Cj PV 6 tube amp, The regulator for the high voltage B+ is consist of MJE 340 controlled by MPSA 42. The output is about 380 Volts DC, while the input could be as high as 470 Volts due to the high AC of 242 V vs the transformer stated 230V primary.
As I increase the smoothing capacitors, the voltage rose to near 500V and blowed out the MJE 340 and MPSA 42. I am thinking of using MJE 13034 to replace MJE 340. Could any one suggest modern replacement for MPSA 42, and MPSA 92?
What if I use CMOS 2SK2769 which could be found in lots of switching mode PS? Will it sound better then bipolar?
tks and rgds
William
Old 4th August 2009, 03:14 AM   #2
ikoflexer's Avatar
Probably more people would try to be useful if you post a schematic.
Old 4th August 2009, 07:12 AM   #3
Default Good advise!
Yes tks, the schemetic is too big, here is the link:
http://www.drtube.com/audioamp.htm#CJ
or
http://images.google.com/images?q=conrad+johnson&rls=com.microsoft:en-SG:IE-SearchBox&oe=UTF-8&sourceid=ie7&rlz=1I7ADBR&um=1&ie=UTF-8&ei=6N53Sr-nNoOHkAWI6IC0Bg&sa=X&oi=image_result_group&ct=titl e&resnum=5
William
High Voltage Regulator mod_evil Power Supplies 36 28th October 2011 12:48 PM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
High Voltage regulator PS maxpou Power Supplies 1 29th April 2006 07:14 PM
High voltage regulator sparkle Tubes / Valves 45 29th August 2004 05:52 AM
Page generated in 0.07056 seconds (69.67% PHP - 30.33% MySQL) with 10 queries
