Hi there,
I'm building a preamp and will be using relays to switch the inputs. Are there any best practices I should follow to minimise input crosstalk? Grounding etc? I've seen designs that use a large resistor to signal ground on each signal input and others that don't. Thanks. |
#2 |
If high impedance inputs are left floating they can pick up hum and noise.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
See this thread;
preamp question
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 |
try searching the Forum.
This has been discussed many times.
regards Andrew T. |
#5 |
Andrew, you are a very knowledgeable chap, but you aren't half a rude so and so some times. Was there any real need to post that?
I did search. Just for the wrong terms it seems. I actually spent 30 mins trawling through non-relevant stuff before posting. But thanks for your helpful input in any case. |
#6 | |
regards |
| PGA2310 and Source Selection, right direction? | geekysuavo | Chip Amps | 43 | 22nd April 2009 06:21 PM |
| Source Selection IC | danward79 | Parts | 28 | 25th November 2008 01:13 AM |
| Relays for Source Selector | SRMcGee | Everything Else | 1 | 9th November 2008 11:02 PM |
| Preamp noisy - 100K pot?Relays? | Tex Houston | Solid State | 45 | 9th August 2007 01:27 AM |
| BOSOZ source switching with SE relays | Gabrielshorn | Pass Labs | 2 | 5th February 2004 09:07 AM |
| Page generated in 0.08816 seconds (73.39% PHP - 26.61% MySQL) with 10 queries |
