Hello fellow DIYers,
I have read through and experienced the dreadful costs associated with converting the voltage of Krell equipments. While I have read the other threads converting via flipping switches, my vintage KAV 300i is using jumpers on the power pcb board. Anybody can help me with this? the primaries to the toroids are coloured Blk-Blu-Org and White-Yellow-Red. Toroid is by Tortran. I had tried to get the toroidal trans from Tortran but to no reply. Krell was willing only to tell the flipping switch method, but mine was not of that version. Then they are gone! No more replies at all. Glad to have found this forum! Cheers! |
#2 |
Can you post a photo of the primary wiring and the connection?
Are you able to create a 110Vac supply to allow you to do some measuring?
regards Andrew T. |
#3 |
I have figured it out. Dismantled the toroidal and found that Black-Green-orange corresponds to 0-100-120V, and Red-Yellow-White to be 0-100V-120V respectively. I could not dismantle the power PCB to look at the circuit underneath the jumpers......however a little trick does it....I used a small torch light to shine under the PCB and track the lines underneath the PCB. So here it is:
Krell KAV-300i jumpers version Originally 120V: jumpers 12 to Jumper 3, J10 to J5 , J9 to J6 (total of 3 jumpers) 240V operation: J12 to J3 , J5 to J6 (total of 2 jumpers). 220V operation: J12 to J3 , J5 to J7 (total of 2 jumpers). This should take care of all voltage conversion issues.......cheers! |
#4 |
hi
I have a krell kav 300i as well... (and i love it) I have never done any DIY on audio but now I need it to run on 110V and krell are asking for 500$... do you have a link to a detailed explanation of what i need to do in order to do this myself ? or a link to a shop in California that could help me ? thanks in advance .. itai |
#5 |
I used another of Krell 300i, it 's not the jumper version (please see attachment)
Does anyone know how to convert it to 220-240 volt? thanks |
#6 |
help! please
| KRELL KAV 300I Schematic Anyone ? | vdavidov | Solid State | 10 | 5th December 2011 02:15 PM |
| Need a krell 300i amp schematic | soundcrafters | Solid State | 47 | 4th November 2007 11:15 PM |
| krell 300i amp. schematic needed | qno | Solid State | 5 | 11th April 2007 07:30 AM |
| Krell KST-100 voltage conversion | Shiva5 | Solid State | 2 | 12th January 2006 08:55 AM |
| voltage conversion for krell audio video standard | james559 | Solid State | 0 | 17th February 2005 07:17 AM |
| Page generated in 0.08969 seconds (71.91% PHP - 28.09% MySQL) with 11 queries |
