I only got a 38-0-38 @ 8ampere transformer available,,,but the designed I got from the web required for about 50-0-50 @10 ampere can any one help me on the design to acquire the 400 watts rms.... if there is can anyone provide me also a PCB layout.....
thankz and more power to all diyaudio member.... |
#2 |
I got 170W into 8r0 from a 230:40+40Vac transformer run on 240Vac.
regards Andrew T. |
#3 |
I would expect you to get 250-300 watts with a 4-ohm load using that transformer.
Just a hunch (without the arithmetic), but I don't think a 2-ohm load is advisable with that transformer, but it would probably provide 400 watts before it burst into flames. ..Todd |
#4 |
I would take about an hour to burst into flames. You'd notice the 'heat smell' long before that. And if there's a thermal cutout device installed it would trip before things got out of hand.
It's still a bigger trafo than what they usually get away with in store-bought amps. |
#5 |
how about if I'll use the LM4702 together with a darlington pair output transformer using a 35-0-35 @ 8 amp. transformer how can I get the 400 watts output..Is it possible to attained the 400 watts rms @ 8 oms
#6 | |
for starters, you can give the dimensions of your 30-0-38@8amps transformer, the wieght, what size core does it use and then we can judge... what about dc resistance of the primary and secondary windings? can you measure them and report here? these numbers that i mention will tell if what you have is sufficient or not... from experience, there is not a world of difference between an 8 and a 10, for all we know, your 8amps traffo would probably suffice....
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#7 | |
the psu matters a lot, if you want the figures at 2ohms, you better have a power transformer that is robust and able to supply that power....
#8 | |
Please sit down and reconsider your projekt......... From your posts here, I assume that you are not very experienced (Cheer up. We all had to start somewhere). Building a power plant amplifier delivering 400W into 8ohms is not an easy task- even if you have a working circuit schematic and perhaps also the PCBs for it. There are so many things that can go wrong, and it could easily end up as a big Your transformer will NEVER give you 400W into 8ohms! For that you need +/-80VDC rail Voltages. Your transformer (one place you state 2x35VAC and next 2x38VAC) will only give you app. +/-50VDC rail Voltage = 150W into 8ohms. You can reach 300W by making 2 identical amps and bridge them. But then you need two trafos + lots of uF in the PSU.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#9 |
Jan Dupont is absolutely right. Reconsider your project. Start with something smaller and simpler. Do not try to build an amplifier, if you do not know yet, how to calculate the achievable power from a voltage and impedance with Ohm's law.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#10 | |
regards Andrew T. |
| Total amount of audio power worldwide (Watts) | Chendy | Everything Else | 11 | 5th May 2009 11:56 PM |
| Watts Audio PAM16 DAC? | Flash53 | Digital Source | 0 | 19th November 2006 02:07 AM |
| Badly in need of help on output inductor design for ZXCD1000 based 500 watts amp | Razor_Edge | Class D | 27 | 17th November 2005 08:37 AM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Page generated in 0.13124 seconds (78.46% PHP - 21.54% MySQL) with 10 queries |
