Old 29th July 2009, 02:51 PM   #1
Default Attenuator doesn't attenuate. Not enough impedence?
I have a 10k ALPS RK097 (the little green one) on my preamp, and It doesn't really do much. It certainly doesn't stop the sound when it's turned all the way down.
Is that because its only 10k? Should I get something like a 50k?
Thanks.
Old 29th July 2009, 04:29 PM   #2
Sounds more like a wrong connection. If you look at the potentiometer from the front (knob) the left pin goes to ground, the right to the RCA connector and the center pin to the amplifier's input.
If that does not cure the fault, post a schematic of your amplifier.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th July 2009, 08:08 PM   #3
tinitus is offline tinitus  Europe
Last time someone presented a similar problem it was wired wrong
Old 29th July 2009, 11:49 PM   #4
AndrewT is online now AndrewT  Scotland
you may have it wired as a variable resistor rather than a volume control (attenuator).
regards Andrew T.
Old 29th July 2009, 11:58 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Center tap shunts input. 2 wires need to be resoldered.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
How to attenuate the alt kerrysun Full Range 1 30th October 2008 09:12 AM
Attenuate tweeter level by 2 db bastek Multi-Way 8 27th May 2008 10:08 PM
how to attenuate aleph p 1.7 elviukai Pass Labs 13 9th March 2007 05:47 PM
how to attenuate a speaker as a mic? newmz Instruments and Amps 2 14th February 2007 05:29 AM
Attenuate? muhy3 Multi-Way 3 24th October 2004 01:53 AM
Page generated in 0.06119 seconds (82.73% PHP - 17.27% MySQL) with 10 queries
