Just wanted to share an excellent sounding little power follower that I have been working on. It uses the Aleph ccs concept to control bias. Sorry I dont have time to give more info atm, more later tonight.
#2 |
Triple emitter follower and servo with a positive feedback?
Looks interesting.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Oops, positive feedback in the dc servo was a mistake on my part. I guess thats what I get for doing things in a big hurry. Heres a revised schematic including the power supply regulators. Will give a parts list etc.. later. Have to go back to work.
#4 |
Why did you decide to use a symmetrical topology, if anyway it is a class A amp? Symmetry is nice when you want to save an energy, but for class A it is suboptimal.
Here is the concept that I've found still the best for class A amp: A counter-modulated current source on bottom minimizes current variations through an output source follower, while an additional source follower on top minimizes voltage variations between it's drain and source. As the result, distortions caused by capacitive load of the previous (tube) stage, of variations of capacitances and transconductance with voltage, current, power (hence temperature) are minimized without any additional feedback, hence without additional high order distortions. ![]() I am currently working on a new prototype that uses this concept: http://www.diyaudio.com/forums/showt...39#post1889739
#5 |
Here is the power supply with Radio Shack part numbers.
#6 |
The regulators with part numbers. The 2sc5200/sa1943 I got from here http://cgi.ebay.com/2SC5200-2SA1943-...d=p3286.c0.m14
The bd139/140's I salvaged from a couple broken Nikko RC cars. |
#7 |
3 lowpass filters in a high gain loop?
#8 |
Yours more stable and higher impedance than trying to drive two
complimentary Alephs directly into the emitters. And the single emitter drop across the split sense resistor(s) makes for less resistance seen in series with the load. I've got two emitters drop, and usually throw schottkys in there to take up some of voltage gap. But, I am also biased for AB.... I'm still not sure which emitter, or the center, is the best place to hitch the bootstrap. It definitely affects stability. Was my intent to copy a triode's plate voltage swing and both share the load, such that it appeared a much bigger triode. Needs just such a follower to make that happen the right way. |
| Comments please, on my class A follower | DRC | Solid State | 17 | 5th March 2007 08:41 PM |
| Class A2 SET using source follower driver | Audio_idiot | Tubes / Valves | 10 | 2nd December 2006 12:21 AM |
| Power follower class A Mosfet DC coupled. | Mr. Steve | Solid State | 30 | 15th February 2006 06:04 PM |
| Class A power follower | Drasius | Solid State | 14 | 21st January 2005 07:47 AM |
| Cathode follower Class A output stage? | Circlotron | Tubes / Valves | 14 | 15th May 2003 11:11 PM |
| Page generated in 0.10056 seconds (74.32% PHP - 25.68% MySQL) with 11 queries |
