Genuine BUZ901/906 or not?
Old 28th July 2009, 07:06 PM   #1
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Default Genuine BUZ901/906 or not?
Found them in my local store, tested for Vgs at 30VDC and 30mA bias. Results are:
BUZ901
Vgs 615mV x 1 psc
Vgs 617mV x 3 psc
Vgs 618mV x 4 pcs
BUZ906
Vgs 847mV x 1 pcs
Vgs 866mV x 1 psc
Vgs 867mV x 1 psc
Vgs 869mV x 1 pcs
Vgs 875mV x 1 psc
Vgs 884mV x 1 psc
Vgs 890mV x 1 psc
Vgs 898mV x 1 pcs
Is there any other test I should do to see if they are real lateral M-fets or not?
Non é mai abbastanza...
Old 28th July 2009, 08:51 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Post removed.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 28th July 2009, 09:31 PM   #3
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
aparatusonitus,
they look extremely genuine, from MagnaTEC and SML [ Small - Medium - Large ].
Old 28th July 2009, 11:20 PM   #4
jaycee is offline jaycee  United Kingdom
The SML branded ones are made by Semelab and appear genuine.
The ones branded TEC might well be Magnatec but they look a bit suspicious. Do the acetone test on the cases.
Old 29th July 2009, 12:33 AM   #5
burbeck is offline burbeck  United Kingdom
hi
i agree with jaycee the TEC ones look suspicious, i understood that Magnatec were a brand name of SEMELAB as is SML.
see here http://www.semelab.com/magnatec/mosdata.shtml
an email to the guy at foot of the page should clear up the confusion
regards
bob
Old 29th July 2009, 05:55 AM   #6
Thanks all for replay
Could you elaborate how to do it?
Also, found this http://www.bilder-hochladen.net/files/1kxe-73.pdf
On line translation from german to english:
"BUZ901 Here first times the mentioned transistor And here the left to the data sheet http://www.magnatec-uk.com/pdf/magnatec/BUZ900.pdf On the fast one we can take the data sheet the following! We go again to my copy: After data sheet it would have to be so occupied. Thus as next would like I unite measurement with the component tester of my oscilloscope to present. First measurement: on the gate, otherwise this measurement a short-circuit can pretend the connections of the component tester between SOURCE and drain, a finger, if a remainder load at the high impedance gate connection is present. To mark I would like still that it a N-type concerns. To the component tester: In X-direction the tension in Y-direction the river. On that right side will the red connection positive, to the left of the 0-Linie (centric) becomes negative it. The sharp break on the right side shows upward that the transistor is leading reverse. On the left side the triangle form forms, by my contact with the finger. A cause is for it the frequency ☺ That is a typical behavior for an enhancement-mode. But stop, why it becomes on the positive page reverse leading. It acts nevertheless around a N-type. SOURCE is appropriate for gate Drain SOURCE but at mass of my component tester, normally thus the sharp break would have up go to the left side downward, and on the right of the gate influence become evident. We go to the thing on the reason: In the next attempt I short circuit now the gate with the SOURCE connection. SOURCE is after data sheet the housing. Now however the behavior does not fit absolutely any longer! Normally the transistor would be allowed to do only the break up-white, where it becomes leading reverse. Only explanation: The housing is that drain and not SOURCE. We continue to go out however of a N-type. Now I want to know it and wedge times the short circuiting bridge between the two pins: Now however the transistor closes as it belonged and shows up only the break for „the Rückwärtsbetrieb “thus must that SOURCE, pin two be, now is also clear it, why the break is on the wrong side. Thus we put the black ones to repeat now at pin 2 and the red one to the housing and the measurements: Now the assumption is set up: Pin 1 gate Pin 2 SOURCE Housing drain N-type Short circuiting bridge between gate and SOURCE, red at the housing: First point for the assumption! Short circuiting bridge between gate and drain, red at the housing: Second point for the assumption! Something alternating voltage over the finger at the gate, red still at the housing: The third point! Everything points nevertheless now on it: 1=Gate, 2=Source and Case are drain, or not?"
Old 29th July 2009, 06:18 AM   #7
Banned
aparatusonitus,
admittedly, I`m not sure, however:
Old 29th July 2009, 09:10 AM   #8
R.I.P.
The Vgs voltages seem very high for Laterals passing 30mA.
I get around 500mV for 100mA with 1058/162 when matching them
regards Andrew T.
Old 29th July 2009, 09:25 AM   #9
That's my opinion as well, as Vgs at original 2SK134/2SJ49 in an Sanyo Plus P55 power amp, according to service manual, should be at ~400mV with +/-58,5VDC supply and 25mA of bias. So, it seems they are fake, right?
Old 29th July 2009, 10:11 AM   #10
Banned
aparatusonitus,
not necessarily, just different from the Hitachi devices. I still would use them.
Genuine BUZ901/906 or not?Hide this!Advertise here!
Genuine 2SC5200 ??? Graham Maynard Solid State 109 30th November 2011 08:23 PM
fake and genuine together? bigpanda Solid State 12 12th April 2007 10:23 PM
FS : 16 pieces of BUZ901 & BUZ905 ANALOG GUY Swap Meet 0 15th September 2006 07:06 AM
WANTED BUZ901/906P Mosfets Zero Cool Swap Meet 1 27th December 2005 03:54 PM
US Source for BUZ901/906??? Zero Cool Solid State 2 25th December 2005 06:03 PM
