Old 28th July 2009, 05:47 AM   #1
Question How to do the best of connection in multi-CAP power supply
Hello there,
Can anyone tell me how do the best for the load connect to the DC source according to attached picture ?
This is the real wiring path in my power AMP DC supply and doesn't follow any regulation circuit.
CK
Old 28th July 2009, 07:27 AM   #2
F-6, and don't forget small capacitors next to the load.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 28th July 2009, 10:26 AM   #3
I am not sure what will be got, if F-1 be used.
Old 28th July 2009, 10:48 AM   #4
AndrewT is online now AndrewT  Scotland
connect the load to D & 4, to minimse the inductance of the cabling.
Twist the cables from transformer to rectifier.
Twist the cables ab with 12
Twist the cables from smoothing caps to load.
Is the load an amplifier?
Then run the power supply traces right next to each other as much as possible and keep the power ground trace as near as possible.
Look at
http://www.diyaudio.com/forums/showt...60#post1890160
regards Andrew T.
Old 29th July 2009, 03:07 AM   #5
Yes, the load is power AMP.
I read the passage and understand how I connect them. Thanks.
Old 29th July 2009, 07:19 AM   #6
Is the additional impedance from D to E and 4 to 5 significant? And if so, would it not improve the filtering, when it is before the last pair of capacitors and therefore be a good thing? Or if it is bad, would the consequence be to connect the load right in the middle between C - D and 3 - 4? And should A and 1 also be connected to that same point?
According to capacitor manufacturers the right way to do it is disconnect 1 from 2, connect 1 to 5 and connect the load between E and 2, provided all capacitors are the same size.
Old 29th July 2009, 08:48 AM   #7
my reasoning follows along the rCrC philosophy.
the first C in the group is the first C in the rCrC.
This is then followed by the longest (=highest impedance) route to the output.
The other three have two equal length wires and one zero length wires. This combination have the lowest impedance connections possible if one does not stack the caps on top of each other.
The r in this arrangement is tiny but it must have some effect and it cannot do any harm.
A reminder of what I said before. The first Cap in an RCRC or LCLC smoothing arrangement suffers high ripple.
regards Andrew T.
Old 29th July 2009, 10:01 AM   #8
infinia is offline infinia  United States
infinia's Avatar
You can hook it up pretty much as you've drawn it, but the key part is to tap the load off of the last cap as close to its terminals as possible. This will effectively keep Vripple lowest.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 29th July 2009, 10:07 AM   #9
The question is, whether the r between the capacitors is significant. There were no values in the first post. The r could be so small that the set-up should be treated as parallel configuration of capacitors, i. e. rC instead of rCrC.
And should therefore have low ESR, the lowest possible voltage rating and the biggest possible physical size. Plus sufficient airflow around it, which many people also like to forget.
Old 29th July 2009, 10:12 AM   #10
infinia's Avatar
You 2 guys like to split hairs. Just use wide traces to promote sharing caps esr, and the key part is to tap the load in the right place. You learn this stuff by building high performance SMPS.
power supply choke with a connection for AC ground? jarthel Tubes / Valves 4 16th March 2007 10:10 PM
Multi power supply argonrepublic Power Supplies 0 7th March 2006 01:04 AM
power distrobution in a multi-way system maxw Multi-Way 10 24th August 2005 09:17 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Page generated in 0.08882 seconds (86.56% PHP - 13.44% MySQL) with 11 queries
