Right Subwoofer being "sucked in" when Amp is turned on.
Old 27th July 2009, 03:03 AM   #1
eddiemoffett is offline eddiemoffett  United States
Default Right Subwoofer being "sucked in" when Amp is turned on.
I'd appreciate it if anyone can help. I just bought a used Alesis RA-100, and whenever I turn it on, my right subwoofer gets sucked in all the way. It seems like it's getting too much power or something. Any ideas?
Thanks.
Old 27th July 2009, 03:22 AM   #2
Samuel Jayaraj is offline Samuel Jayaraj  India
It is more likely that the DC offset voltage is relatively high in that channel.
Sam
Old 27th July 2009, 03:36 AM   #3
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
It can only be DC-offset causing this type of action.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 27th July 2009, 05:14 AM   #4
SQLGuy is offline SQLGuy  United States
Hi Eddie,
Just to be clear, in case you're new to this, this is a pretty bad sign. It means the amp is in need of repair and could easily damage speakers it is connected to. Do not use it until it's been repaired. The problem with the amp itself could be as simple as one or two small transistors that are bad, or as complex as the whole output section blown.
Sorry for the bad news.
Paul
Old 27th July 2009, 05:37 AM   #5
DCPreamp is offline DCPreamp  United States
DCPreamp's Avatar
Is the woofer getting pulled in and it stays in, or does it just pull in and then relaxes back to normal?
If it pulls in and stays, then you have a serious problem.
If it pulls in, then returns to normal, then you may have a minor problem or it may be a fluke with Alesis amps (like a weird bridging turn-on spike only affecting one channel).
Either way, address it and correct it or you could lose your speakers.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Old 20th November 2009, 01:35 PM   #6
Mcurmi is offline Mcurmi
I have the same problem and i have had a channel blown on the amp and i was not turning on since i was staying in the protect mode. Now i changed 4 transistors and 2 rectifiers and the amp is turning on but the sub woofer is being pulled in and stays in. What else should i check apart from transistors??
By the way my amps's channel was damaged because it was turned on without any heat sink (therefore over heating)
Old 20th November 2009, 03:56 PM   #7
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
Please disconnect the speakers! Use a meter to measure the offset, there is no need to attach speakers.
Once the source of the problem (driver transistors, Outputs, power supply etc ) has been found then test using a dummy load (8 / 16 ohm heavy duty resistor ) and make sure it is well before attaching your speakers.
Right Subwoofer being "sucked in" when Amp is turned on.Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Are changer wires "dead" when turned off? whiterabbit Car Audio 0 16th February 2009 01:11 AM
FS:Tang Band W69-1042M 6"x9" Subwoofer - Free Shipping YFW Swap Meet 3 15th August 2008 12:51 AM
Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer MyNameIsJake Subwoofers 4 26th January 2008 02:57 AM
open baffle subwoofer "enclosure" dimensions noodle_snacks Multi-Way 4 18th July 2006 06:51 AM
