Boost your amplifier
Old 26th July 2009, 09:40 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Boost your amplifier
Good day to all
the booster that you see attached is a project that sees the CFP renewed because using the same components as driver like final
this method compensates for differences in absolute gain of the complementary devices
making the stage of current gain stable
and with natural sound
This simple solution allows you to abandon the EF output type
notoriously slow and lacking in vitality
an idea that soon will generate the enthusiasm of the fans
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 27th July 2009, 01:53 PM   #2
h_a is offline h_a  Europe
h_a's Avatar
Hi Stee,
I really like your enthusiasm
However, I don't really see the advantage in your approach. If you use high power outputs also for drivers, you will need a pretty powerfull VAS or, again, a driver to drive them. Also hfe between upper and lower bjts is not matched, so variations are always possible.
Why not simply use high beta CFP-drivers, such that the product of the CFP-hfe's is almost independant of the output bjts?
Have fun, Hannes
PS: by the way, the 'simple' operation of dividing numbers is not commutative. Neither the multiplication of matrices.
High Octane phono preamp Wiki
Old 27th July 2009, 02:19 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Interesting, I have been thinking along similar lines for a current amp where differences between complementary sides is holding back the performance.
Anyhow, it seems to me that you need to set up the CFP so that all the devices are experiencing the same conditions to achieve a good match - same current flow through both the 'master' and 'slave' devices of the CFP. Unfortunately it does move the onus back to the drivers to provide enough current but again, the drivers can also be designed to minimize differences by using CFP ! Obviously you then need to use a single ended VAS.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th July 2009, 03:02 PM   #4
h_a's Avatar
Which case would be that? I would be very curious about this as in my experience distortion cancellation in complementary circuits is nice, but not extremely effective.
Have fun, Hannes
Old 27th July 2009, 03:30 PM   #5
Bigun's Avatar
I made a topology for a current amplifier in my simulations that had very low distortion when using the ideally matched default spice models it doesn't work nearly so well when the complementary devices are mismatched.
http://www.diyaudio.com/forums/showt...48#post1887648
Old 27th July 2009, 04:03 PM   #6
Professor smith is offline Professor smith  United Kingdom
Banned
Why not?
Old 31st July 2009, 07:57 PM   #7
Stee's Avatar
Default Matching devices
you will need a pretty powerfull VAS or, again, a driver to drive them:
see the new self-biased current drive
match same PNP (for example 97 and 97) and same NPN ( 43 and 43)
it's easy
Old 31st July 2009, 08:47 PM   #8
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default Re: Boost your amplifier
Originally posted by Stee
Good day to all
That circuit will suffer from crossover distortion.
It really needs a good bias stage.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 3rd August 2009, 05:59 PM   #9
Stee's Avatar
Default distortion is a resulting problem
for bias it's possible connect one NTC resistor between second base's copule
distortion in CFP come from different absolute gain between two rails
Old 4th August 2009, 07:35 AM   #10
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Very usefull booster Stee..thank you.
I have several nice audio chips...and they sounds very good and can produce the needed voltage to drive your circuit.
This is very usefull, a very helpfull style of circuit... this way we can use our toys and your booster will produce the needed punch...exactly were those chips fails.
Their small case to dissipate heat limits the power, also the protections they use to overcurrent and peaks are a problem too... we can use them without drive the protections..as all that stuff kill chip amplifiers quality...adding the booster you suggest, we can use them in more safe way..loading them lightly and avoiding them to operate into the distortion levels..and even this way we gonna have a nice power to the speaker.
This is creativity...new simple solutions to the daily problems... to offer things we can use... my respect and congratulations fratello Stee.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Boost your amplifierHide this!Advertise here!
11.5-12.8v to 13.8-14.4v boost star882 Power Supplies 16 19th May 2010 03:13 AM
to boost or not to boost? CharlieM Subwoofers 1 31st January 2009 06:17 PM
[enquiry] Treble Boost/High frequency Boost circuitry elnino86 Parts 2 18th December 2008 12:33 PM
1kW Boost allanon77 Power Supplies 17 4th February 2008 12:18 PM
EQ boost and Q......help Javaman Multi-Way 1 20th January 2002 02:15 PM
Copyright ©1999-2017 diyAudio
