Old 26th July 2009, 08:05 AM   #1
fotios is offline fotios  Greece
fotios's Avatar
Default Balanced input impedance
Question:
In the specification brochure of an amplifier which includes except the usual single (unbalanced) inputs also balanced inputs, is refered except the single input Zin also the Zin of the balanced input.
For the single input, the Zin which refered is quite comprehensible, because is measured between the signal input terminal and the ground.
For the balanced input i can not understand where is measured: Between the Hot pin and the Gnd? Between the Cold pin and the Gnd? Between the Hot and Cold pins?
I have to refer an example. In the specs of a well known power amplifier, is refered:
Zin unbalanced = 50KÙ. By measuring it with a multimeter - in rough of course - it is true. The multimeter shows 47,5ÊÙ.
Zin balanced = 15ÊÙ. By measuring again with the multimeter, the impedance between the Hot pin and the Gnd it is almost 15ÊÙ. Instead, between the Cold pin and the Gnd it is 30ÊÙ.
When the Zin of a balanced input is measured with a normal impedance meter, between which pins is reffered? It is obvious that the Cold signal input has absolutelly different Zin (respect to Gnd) from the Hot signal input.
Can someone to explain me this?
Fotios
Best Regards FOTIS ANAGNOSTOU
Direct Contact: eal@dra.forthnet.gr
Old 26th July 2009, 10:11 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I think it would help if you post a schem of the actual circuit
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 26th July 2009, 12:33 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Fotios,
Nrmally there should be two impedances: the differential mode impedance which is measured between hot and cold, and which is what would be important for the balanced out driving stage.
Then the common mode impedance is the impedance measured from both the hot and cold to gnd. Normally this is not important for the driving stage.
jd
/Another new issue: Linear Audio Volume 3!
Old 26th July 2009, 05:12 PM   #4
fotios's Avatar
Thanks guys for the replies.
@ Jan Dupont: To help you, i talk about a Bryston 4BST-Pro that i have in my stock. You can find very easy the whole schematics from the site of Bryston (i suppose you have those already).
@ Janneman: I did a rough differential measurement between hot and cold pins, and the multimeter shows 41,5ÊÙ. This is a big diference from the refered 15ÊÙ from Bryston.
I have report the rest measurements in my first post.
To my eyes, Bryston refers as balanced input impedance this between HOT pin and GND
Fotios
Old 26th July 2009, 07:08 PM   #5
janneman's Avatar
Fotios
Yes, could be, if they don't specify whether the number is for differential or common mode you don't really know. Also, input impedance measured with the multimeter may not be the same as the input impedance for the input (ac) signal.
jd
Old 26th July 2009, 08:04 PM   #6
cbdb is offline cbdb  Canada
Heres the schema. The input impedance when switched to ballanced should be across hot and cold (pins 2 and 3). The Zin3 goes thru the 10K right into the OP Amp so a meter probably wont read this properly.
Old 27th July 2009, 09:45 AM   #7
AndrewT is online now AndrewT  Scotland
the asterisk * on the 10k next to the -IN pin is the virtual ground of the (discrete) opamp.
XLR3 sees this 10k as the input impedance.
XLR2 sees the 6k65+3k32 as the input impedance.
These should be matched to <0.1% for the balanced connection to work well at attenuating interference.
The capacitance from these two XLR pins also needs to be matched to maintain rejection to higher frequencies.
regards Andrew T.
Old 27th July 2009, 10:19 AM   #8
in the same way that you can measure output impedance, you can measure your Hot to Cold impedance.
Check your source output impedance.
Add a resistor into the hot line and measure the voltages at the resistor and across the XLR.
As you vary the in-line resistor you will be able to calculate the input impedance.
regards Andrew T.
Old 27th July 2009, 09:24 PM   #9
The * means the components are matched ( says right on the schemat ). The -ve in pin is not a virtual gnd. It is at the same voltage as the +ve in pin, about a 1/3 of the voltage at XLR2.
PP to balanced input wicked1 Tubes / Valves 7 25th February 2009 10:21 PM
10k nfb and 10k input impedance. Anyone tried it? danielwritesbac Chip Amps 13 4th December 2008 04:51 AM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Balanced Zen Line Stage Output Impedance? AudioAngel Pass Labs 6 29th December 2006 07:38 PM
[P68] Balanced input??? Tazzy Solid State 9 8th February 2003 12:52 PM
Page generated in 0.11452 seconds (77.00% PHP - 23.00% MySQL) with 11 queries
