The most linear stage for large voltage swings - Lender's Circuit - Page 4 - diyAudio
Old 28th October 2009, 08:52 AM   #31
tiefbassuebertr's Avatar
Originally Posted by Bonsai View Post
"by the thread title you'd be better off pursuing cascodes:
REDUCTION OF TRANSISTOR SLOPE DISTORTION IN LARGE SIGNAL AMPLIFIERS, M.O.J. Hawksford, JAES, vol.36, no.4, pp.213-222, April 1988
http://www.essex.ac.uk/csee/research...%20cascode.pdf "
This is the VAS technique I was refering to in my earlier post on this thread.
Using the simple standard current amplifier topology front end, but modding the VAS stage to use Hawksfords technique, I consistently get THD (simmed) below 500ppb. Between the VAS and the load, I'm using a diamond buffer. Hawksfords VAS is really amazing in my view. This weekend, I plan to mod my power current power amp VAS to Hawksford (I was supposed to do it a few weeks ago, but have not had time).
Thank you for this advices. here the right link:
1) http://www.essex.ac.uk/csee/research...%20cascode.pdf
If don't goes open please copy this in the URL address field and add the correct characters at the beginning and at the end as a substitute for the wrong
2) http_www_essex.ac.uk/csee/research/audio_lab/malcolmspubdocs/J10%20Enhanced%20cascode_pdf
then the URL will no longer be mutilated further through this forum
Old 10th November 2009, 03:54 PM   #32
on this thread I read about some application notes from Motorola.
AN-483B (post #5 could be exactly the version, that I ask
Anybody have scan of AN-483B (Motorola)?
But I am not absolutely shure.
Perhaps one of you can post this exemplare - I don't find it online.
Old 10th November 2009, 06:15 PM   #33
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
tiefbassuebertr,
just curious - were you ever able to find the original paper from lender?
mlloyd1
Old 10th November 2009, 06:29 PM   #34
Originally Posted by mlloyd1 View Post
tiefbassuebertr,
mlloyd1
No - therefore I have started this thread. Please read post #1. If I had found the original paper, I wouldn't post here.
Old 10th November 2009, 09:42 PM   #35
forr is offline forr  France
forr's Avatar
I only met Lender's name mentionned by Boberly and Self.
In all the editions of Self's book on power amps, the Lender's circuit shown seems to have wrong values of resistors.
Old 10th November 2009, 11:04 PM   #36
djk is offline djk
djk's Avatar
His name is spelled:
http://www.borbelyaudio.com/
His 1982 Audio Amateur EB60 amplifier has the Lender circuit explained.
Candidates for the Darwin Award should not read this author.
Old 13th May 2012, 09:33 AM   #37
Audio | Digital Voice Recorder | Bose Wave Radio | Editor | Speaker Jbl at Borbelyaudio.com
This article I have in the associated book about
Audio Amateur Power Amp Projects - Circuit Cellar, Inc.
or
Audio Amateur Power Amp Projects | CE Distribution LLC
This article has prompted me to start this thread nearly three years ago.
I need the by post #1 mentioned genuine paper from Motorola
Old 14th May 2012, 12:53 AM   #38
djk is offline djk
djk's Avatar
Sorry, I remember reading it, but don't have a copy.
Old 6th April 2013, 09:14 AM   #39
concerning the phono mm mc preamp "SUPRA" I have questions and have posted therefore by this thread (POST #27):
SLN Pre-Amp - Elektor Aug 1982
Old 6th April 2013, 01:15 PM   #40
Banned
Originally Posted by tiefbassuebertr View Post
The most linear stage for large voltage swings - Lender's Circuit...
There is no evidence anywhere that this is true.
Heater to Cathode max voltage specs, including signal swings? flysig Tubes / Valves 2 28th June 2009 09:22 PM
Generating big voltage swings without 'iron' bigwill Tubes / Valves 14 25th May 2008 02:44 AM
Large capacitors low and high voltage rkc7 Swap Meet 0 24th March 2006 02:17 PM
The long lost linear gain stage smoking-amp Tubes / Valves 43 31st January 2006 04:28 AM
Phase Linear 200 Circuit mrfeedback Solid State 4 5th December 2004 09:48 AM
Copyright 1999-2017 diyAudio
