I'm looking at the Aksa 100 as a possible project. Two questions- can a rank beginner handle this, and how difficult is it to build this as dual mono?
#2 |
It should be okay if you know how to solder and use a multimeter, and understand how the power supply works.
By dual mono, do you mean completely separate power supplies for each channel? If so, then it's no more complex, just more work and more parts required, more chassis space required, etc. How does the AKSA 100 come? Pre-assembled, or do you need to solder in all the parts? Either way it really just comes down to your soldering skill. If you haven't got much experience, practice soldering something else first until all your connections are shiny and strong and didn't take 4 attempts to achieve. Good luck, it's a wonderful amplifier. Worth the effort. ..Todd |
#3 |
Start small
Even though Aksa amps are "simple" and easy to assemble, just small errors can ruin an expencive project And repair work is the harder part that could ruin it even further if not done properly Im not saying you cant do it, but you should really build a cheap kit first to get just a little feel of how it all works |
#4 | |
The psu is designed as separate for each channel, so it comes as dual mono, with no extra work required on your part. You have to supply the transformers, chassis, and a few other parts. Best to email Hugh directly with your questions. |
| AKSA amp kit | pkgum | Solid State | 134 | 19th November 2008 01:24 PM |
| AKSA 55 vs. ESP P3A vs. ? | Paul Ebert | Solid State | 38 | 1st March 2004 09:13 PM |
| AKSA 55W and GK-1 | harvardian | Swap Meet | 4 | 15th October 2003 08:08 AM |
| New AKSA 55 | ultrachrome | Solid State | 13 | 16th June 2003 02:00 AM |
| Aksa | sdman | Solid State | 39 | 22nd January 2002 04:19 AM |
| Page generated in 0.07828 seconds (67.39% PHP - 32.61% MySQL) with 10 queries |
