#11 | |
But who cares what happens with no ac signal applied ? I jus twant it to sound good with music applied to the input and be reliable. And that is what has happened with my power amps. I have certainly had no complaints from customers.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#12 |
at low AC signals the transistors will be operating at different temperatures if the quiescent currents are unmatched.
Some of the consequences are that the parallel transistors will have different handover times in the cycle, have different gains, have different fT, have different SOAR. Once you have these different temperatures between the individuals of the unmatched parallel sets, this temp. diff. will exist even when larger AC signals are passing.
regards Andrew T. |
#13 |
Over 35 years ago I repaired a quasi-comp amplifier with a random junkbox sourced NPN output.
It measured quite poorly (0.8% THD vs less than 0.1% on the good channel). I suspect the interstage driver transformer may have been damaged, but I really didn't know. No one could HEAR the difference between the repaired channel and the original channel, and I have heard many amplifiers that measured better actually sound worse.
Candidates for the Darwin Award should not read this author. |
#14 |
I think the problem with random use of 2N3055s for audio is that there was no contol of the spec's. everybody and his brother where making them with different processes and even die sizes over all these years. RCA rebranded theirs just for audio use providing at least some control in audio apps versus the normal ubiquitous uses as Vreg pass devices. Probably just use a good name brand device and measure/select for higher gains beta > 50 would be what I'd do. Not matching really.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#15 |
RPL all the output 2955/3055's, checked around the channel where it had shorted and did not find any issues. After replacing, the amp works fine. It's quasi-burning in now - playing all 4 chans at a low volume, just don't want to install it and have to take it all apart again.
| FS: Matched pair NOS RCA 5670 | cartman | Swap Meet | 2 | 10th December 2007 08:12 AM |
| FS: Matched pair NOS CEI 2C51 | cartman | Swap Meet | 0 | 10th December 2007 08:07 AM |
| how do you know you need matched pair? | jarthel | Tubes / Valves | 4 | 11th May 2007 03:57 PM |
| WTB: 5692 (matched pair) | cartman | Swap Meet | 0 | 11th June 2006 06:25 AM |
| i have a matched pair of 3cx1000a7.. | Mr. Triatic | Tubes / Valves | 8 | 4th October 2004 08:29 PM |
| Page generated in 0.08590 seconds (74.94% PHP - 25.06% MySQL) with 10 queries |
