Old 23rd July 2009, 08:59 AM   #1
Default Does quality of negative voltage regulation matter
I've found that better quality, lower noise regulation of the positive rail always brings benefits, be it in cd players, amps, pre-amps etc.
Question: Does improving the negative voltage regulation bring benefits or is it not worth the effort?
Old 23rd July 2009, 09:29 AM   #2
analog_sa's Avatar
If you have a look at PSRR of opamps per example you'll notice the negative supply rejection is commonly better than the positive by 10-20db. IME this doesn't necessarily mean that you won't hear a difference between a Jung superreg and a 337. I was recently shocked to discover that a leading manufacturer uses a sophisticated superreg-type circuit to power the B+ of a differential tube pair and a 337 for the negative supply, obviously assuming that a CCS in the tail will make the 337 invisible. I built it using a 337 and later replaced this with a Jung. Obvious improvement.
Old 23rd July 2009, 01:10 PM   #3
Thanks analog_sa
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 09:25 AM
Voltage Regulation from a battery bigphil Power Supplies 9 14th October 2006 03:44 PM
Does Voltage Matter? soundNERD Chip Amps 36 27th November 2003 06:21 PM
How much does the quality of a sub amp matter? Javaman Multi-Way 7 15th February 2003 07:25 PM
Does component quality matter? r_s_dhar Analogue Source 15 17th July 2002 07:42 PM
Page generated in 0.06855 seconds (73.55% PHP - 26.45% MySQL) with 10 queries
