Old 23rd July 2009, 08:17 AM   #1
A 8 is offline A 8  Sweden
Default Automatic poweramp start
Hoping for some help..
I've got a separate poweramp connected to my main poweramp and would like that to start up as I switch on the main poweramp.
I am thinking it should not be that difficult to get the signal of the speaker output on the main amp and somehow get it to a relay that switch the AC line on the second amp.
I see this feature on a few car amps and was hoping you guys could point me to a supplier or a curcuit that I could use.
Thanks/Michael
Old 23rd July 2009, 08:40 AM   #2
N-Brock is offline N-Brock  United States
N-Brock's Avatar
You might want to take a look at the thread titled "Remote start for DIY sub amp"
It seems to be a similar subject and it might help you out.
Old 23rd July 2009, 08:44 AM   #3
pilli is offline pilli  France
Maybe also something like this
http://sound.westhost.com/project38.htm
_
Old 23rd July 2009, 09:23 AM   #4
Nrik is offline Nrik  Denmark
Don't make things too complicated.
Buy one of these, they are cheap 80DKK /10€ , and get the job done.
http://www.lokalenergi.dk/Files/Bill.../tv_skinne.jpg
STOP - Hammertime!
Old 23rd July 2009, 06:04 PM   #5
Nrik,
This sure would be helpful for my adcom gfa-555II amp that has no 12v trigger! Looking at it I guess its from Germany or something? Is there anything like it that works on 120v in the usa that is cheap and can handle large amounts of current?? I dont want to go buy another panamax that will do this for my amp.
Old 23rd July 2009, 06:56 PM   #6
No - its from Denmark, and everbody are using them for everything.
I am sure it is available all over ecology-oriented Europe, but I don't know about USA.
Everybody in the world should use these to cut back wasted standby energy.
STOP - Hammertime!
Old 23rd July 2009, 09:08 PM   #7
yea I agree, but from looking at the plugs its not for 120vac...And the only thing I know of that will turn things on and off like that is panamax or monster cable surge suppressors line conditioners and they are about 300 to 400 bucks.
Old 24th July 2009, 02:27 AM   #8
unclejed613's Avatar
SSR's are a real handy device, and can be triggered with a DC signal from 2 to 32V. you can usually get them dirt cheap from surplus parts dealers, but even their new prices aren't ridiculous.....
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 24th July 2009, 03:58 AM   #9
well that ssr would really do the job, I found one for 9 bucks that handels 40a at 120vac. Question I see how to hookup the dc trigger, and I guess u would just run a piece of romax to the top 2 screws and then to a wall outlet to plug the amp into???
Old 24th July 2009, 04:15 AM   #10
the AC "contacts" would be in series with the line, preferably on the "hot" (black wire) side. the DC input could be anything, for instance a 9V battery and a toggle switch. if you're running more than about 10% of the rated current of the SSR, i recommend you heat sink it. you will notice the bottom of the SSR is a large metal plate, which is the heat sinking surface. i've seen them just bolted to a metal chassis box with some heat sink grease under them. the switch elements are MOSFETs, so they don't generate very large amounts of heat, but heat sinking is always a good idea
mic preamp automatic gain checko_garcia Instruments and Amps 6 10th May 2008 05:29 PM
Automatic Cooling Fan hernanstafe Parts 14 16th March 2007 11:41 PM
Automatic didgeridoo design. Spasticteapot Instruments and Amps 2 12th February 2006 09:26 PM
Automatic start and stop on Dual Turntable (fully auto) JamesGU Analogue Source 2 9th July 2005 02:30 PM
Page generated in 0.13902 seconds (77.66% PHP - 22.34% MySQL) with 11 queries
