Old 20th July 2009, 07:24 PM   #1
destroyer X's Avatar
Default TDA2030 internal diagram...please...if you have it, send to me
panzertoo@yahoo.com
I have several systems at my home.... even some digital ones.... also several class AB...but i have enormous appreciation of this chip sonics.... it needs, maybe, to my old ears, a little bit high end...maybe internal compensations because small distances from input to output.
I would like to assemble something discrete using the internal schematic...so...having the one, please, send to uncle charlie.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 20th July 2009, 08:32 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
TDA2040 is improved version of TDA2030
and in the datasheet you have simplified diagram.
http://www.st.com/stonline/products/...re/ds/1460.htm
Now, even more interesting is the TDA2050
I would always go for this one, instead of those older versions.
http://www.st.com/stonline/products/...re/ds/1461.htm
All 3 Chips uses basically the same circuit.
lineup
Old 20th July 2009, 08:40 PM   #3
Default Thank you Lineup.... this one sounds fine
I have perceived losses into high frequencies..but i think we can fix this.
regards,
Carlos
Original Bose 901 Internal Wiring Diagram sdep777 Full Range 24 28th February 2010 05:14 PM
TDA2030 internal diagram...if you have it..please, upload to: destroyer X Chip Amps 7 22nd July 2009 10:42 PM
Need internal wiring diagram for Sears by Fisher Full Range jerryeblades Multi-Way 3 29th May 2007 12:59 PM
internal block diagram for CXD1135Q heilman Solid State 2 6th March 2007 07:07 AM
Page generated in 0.09986 seconds (59.30% PHP - 40.70% MySQL) with 11 queries
